AOD tailshaft slop....
Old Dec 22, 2013 | 01:47 PM
Freightrain's Avatar
Freightrain
1989 F150
Ok, I have excessive amount of yoke slop on the output shaft. I pulled the driveshaft and the output shaft wobbles pretty bad. The yoke has no wear on the surface. Don't know how bad the rear bushing is?
Should the output shaft by itself wiggle around unsupported? Or should it be pretty stable by itself? I'm sure I can pull the tailhousing and just replace the bushing but not sure that is the root cause. If the output shaft is wobbling due to bad bearings then the bushing will just get beat up again. Truck has 150K miles, bought it with 80K miles and looks like someone might have replaced transmission? There was a tag wire hanging on the tailhousing mount holes like maybe a reman?
The truck has a shake that is very noticeable around town. On the highway not so much. Really annoying.
Old Dec 22, 2013 | 08:01 PM
jk080's Avatar
jk080
Transmission Rebuilder
The tail housing bushing keeps the shaft still, there will be some movement of the output shaft without the yoke. You should be fine by just replacing the bushing and seal.
Old Dec 22, 2013 | 09:58 PM
Freightrain
Yup, I am going to get a bushing/seal tomorrow. Got someone that will loan me the tool to do it while still in the truck.
Hopefully this will smooth things back out. I replaced some bad tires(cupped) but now I realize there are other issues. One step at a time......
Old Dec 23, 2013 | 05:14 AM
stuart1's Avatar
stuart1
I would concentrate on ujoints and drive line angle.
Old Dec 23, 2013 | 04:00 PM
Freightrain
All stock, nothing has been altered. Got the bushing/seal kit today, tool on the way.
Both u-joints are nice and tight still. Just replaced pinion bearings due to being loose. I think that is what wiped out the tailhouse bushing. Should know by the weekend if everything is back to good.
Old Dec 23, 2013 | 04:09 PM
stuart1's Avatar
stuart1
There is a difference between tight and right.
Ujoints can be rusted and
tight but that isn't right.
BTFordGuy302
16
Mar 26, 2016 10:46 AM
woodtrucker
Jul 25, 2013 09:12 PM
postalxj
Dec 19, 2009 01:10 PM
lurchy98
1983 - 2012 Ranger & B-Series
Sep 17, 2008 01:56 AM
