1978 - 1996 Big Bronco
SROD trans swap???
Old Aug 14, 2003 | 02:34 PM
mr_muldoon's Avatar
mr_muldoon
Question SROD trans swap???
Hey, I have an 82 bronc with 300 hooked up to a baffed SROD transmission. I want to swap the SROD out, what is a near fit to replace the SROD?? Help please.
Thanks
Old Aug 14, 2003 | 04:48 PM
Kemicalburns's Avatar
Kemicalburns
SROD trans swap???
well are you wanting a manual tranny or auto. you could run a c-4 or an np435 manual. just depends on what you want
Old Aug 20, 2003 | 02:38 PM
mr_muldoon's Avatar
mr_muldoon
SROD trans swap???
I want to keep manual trans.
Old Aug 20, 2003 | 03:28 PM
Kemicalburns
SROD trans swap???
i would go with the np435 its a 4speed manual tranny but first gear is a granny gear. it would work well with the 300-6.
later
Old Aug 31, 2003 | 09:28 AM
brokebronco's Avatar
brokebronco
SROD trans swap???
Mr M, I did the swap in my 82. All you need is the NP435 with the adapter(different than the SROD) Make sure you get the tunnel cover that matches the 435 or cut a new hole in the old one and cover the original shifter hole. I did the swap in early 93 so I do not remember if I reused the transfer shifter linkage or not. Works so good I swapped the driveline into my 84 when the 82 totally rusted out.
cjbronco
Nov 30, 2016 12:27 PM
mantis118
Apr 7, 2016 10:44 AM
Pitweiller13
Dec 10, 2015 04:12 PM
keyul
23
Sep 14, 2009 11:05 PM
skeneguy
Mar 5, 2008 05:51 PM
