Sponsored by: Auxito
4x4 option
Old Jun 23, 1999 | 02:02 PM
Sean_2's Avatar
Sean_2
4x4 option
I just purchased a 99 Lariot with 4 wheel drive. I was suprised the owners manual discouraged against using 4 wheel drive on dry pavement. Can this system be used in the rain? Do I have to use 2 wheel drive when turning corners? As a result of the extra $ charged for 4 wheel drive, I expected a setup similiar to the Expedition or Explorer. Is the rear end dangerous in snow and ice?
Old Jun 23, 1999 | 04:31 PM
J.C.'s Avatar
J.C.
4x4 option
You could use it in the rain if you really wanted to but, it's probably best to leave 4wd for snow/ice and off roading. The only rear ends that act funny on ice are ones with lockers which aren't even a factory option.
Old Jun 27, 1999 | 08:12 AM
blckhawk's Avatar
blckhawk
4x4 option
Don't confuse All-wheel drive with 4-wheel drive. All-wheel drive is designed to be engaged continuously and has a system that senses speed changes (loss of traction) in individual wheels all the time. 4-wheel drive is more of a manual system that trys to put traction equally to both ends at the same time. Using this on dry roads with out at least a little traction slip (rain, snow, etc.) will cause binding at best, and broken driveline parts at worst.
Old Jun 27, 1999 | 08:25 AM
blckhawk's Avatar
blckhawk
4x4 option
jayloveland
Mar 28, 2015 01:52 PM
bluesclu978
Feb 13, 2011 07:52 AM
jam92102
2004 - 2008 F150
17
Feb 11, 2009 08:01 PM
6ohin25401
Dec 9, 2007 04:20 PM
lombardo96
Jun 26, 2006 12:22 PM
