302 water pump
Old Jan 2, 2003 | 08:36 PM
getu12's Avatar
getu12
302 water pump
Can someone tell me if the heater hose connection is press fit or screwed into the water pump on a 70 302. I don't want to start twisting on it till I know for sure. Thanks
Old Jan 3, 2003 | 12:26 PM
Franklin2's Avatar
Franklin2
302 water pump
If it has a hex shape for a wrench, it will screw in. Plus you will usually see a few threads sticking out. If it's smooth, it presses in. You will pretty much destroy the old one to get it out.
Old Jan 3, 2003 | 02:16 PM
getu12's Avatar
getu12
302 water pump
I appreciate the response. I guess I'll have to destroy it or get another pump. I need to turn that fitting up at about a 45degree angle so the hose doesn't bind on the alternator spacer. Thanks:-(
Old Jan 3, 2003 | 08:26 PM
Mike W's Avatar
Mike W
302 water pump
Can you modify the alternator? I have never had this problem on early 302's.
Old Jan 3, 2003 | 10:25 PM
wille3r's Avatar
wille3r
302 water pump
maine71f100
Nov 19, 2016 03:37 PM
BigRobK
19
Dec 9, 2015 05:44 AM
Dashknob
May 20, 2015 07:25 AM
dmc919
May 12, 2004 06:48 PM
Skipdaddie
Jan 5, 2003 03:47 AM
