4R100 Overdrive Switch
Old Mar 21, 2008 | 12:24 AM
F-SUPER DUTY's Avatar
F-SUPER DUTY
What would cause the OD switch to not operate.03' 7.3 F350.
Old Mar 21, 2008 | 09:20 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Usually it's the wires are damaged where they enter the shifter handle inside the steering column. You can remove the plastic cover and either repair the wires or replace the shifter for about $50.
Old Mar 21, 2008 | 03:49 PM
rclarke's Avatar
rclarke
The damaged wires often short to ground and blow the fuse. Repair the wires or replace the shift lever and check or replace the fuse.
narrowfarm
Oct 16, 2014 09:22 PM
spidermantat
Dec 16, 2013 05:22 PM
f350powerhouse
Apr 13, 2010 06:26 PM
tompmatthews
Nov 25, 2009 01:19 PM
