Intake Gaskets
Old Mar 20, 2008 | 01:49 PM
OrangeJuice's Avatar
OrangeJuice
Smile Intake Gaskets
Hi everyone,
I noticed a small leak coming from the back of my intake on my 1976 F-100 with a 390. I will have to pull the intake off and replace with a new gasket. Any suggestions on what to use since there is quite the gap on the front and back to fill. The leak seems to be on the right rear corner of the intake. I was told to try a product called The Right Stuff that is sprayed from a can. Has anyone used it and does it really work? Any tricks to try?
Thank You
Old Mar 20, 2008 | 02:21 PM
Bear 45/70's Avatar
Bear 45/70
You may need to have the manifold machined if the heads are cut alot. This is a problem that most are not aware of with the FEs.
Old Mar 20, 2008 | 02:25 PM
Freightrain's Avatar
Freightrain
Right stuff? foam insulation? No, I would NOT suggest using that on an engine.
There is a cork gasket that runs across front/back to fill in the area between intake/block. When I put a motor together for the first time I mock up the parts to see the actual gap. Then I try to fit the cork inserts. If they slide in with minimal gap left, then using silicone I glue them to block, then more on top, then place intake.
If the gap is too tight for cork, then I build up a wall using only silicone(make a tall bead all across block) then let set for a few minutes til tacky and then set intake on.
When you do it with only silicone, place side gaskets on head, then build across block and make sure you blend it up with side gaskets(at corners). This will ensure no leaks.
Like Bear mentioned, check everything for squareness. Might be twisted and that will leak no matter what you do.
Old Mar 20, 2008 | 08:50 PM
Ford_Six's Avatar
Ford_Six
Great stuff is the foam, Right Stuff is a gasket maker in a pressurized can.
I use Import Grey RTV, it seems to handle the big gap quite well.
z 97ford1
Modular V8 (4.6L, 5.4L)
Sep 26, 2014 12:49 PM
bro460
Modular V10 (6.8l)
Jul 21, 2013 07:46 AM
kellar
15
Jan 22, 2008 04:23 PM
90F250351
16
Dec 5, 2006 05:35 PM
Blaine
Apr 17, 2002 09:31 AM
