48 3/4 ton
Old Mar 20, 2008 | 12:42 PM
55 dude's Avatar
55 dude
48 3/4 ton
hello, i am being given a 48' ford 3/4 ton truck and really are not familiar with this year of truck as i usually have 53'+ ford trucks. handful of questions: are the frames different between 1/2 and 3/4 tons? i know one is 5 lug and one is 8? will the toyota 4x4 conversion work on a 3/4 ton and will a 55' 1/2 ton axle fit this truck. the truck is 3 hours away or i would be under it myself taking pic's and measurement. from the searching i have done it sounds like 57'-72' truck rearends fit these, anyone have a measurement wheel mounting surface sise to side. what about wheelbase dimensions and track widths. thanks
Old Mar 20, 2008 | 01:50 PM
bobj49f2's Avatar
bobj49f2
Front axles are the same but the frames are a little beefier than a F-1. If you're interested in converting it to a 1/2 ton contact the member of the board named Greatnorthwoods, he has done this conversion very nicely.
Old Mar 20, 2008 | 03:36 PM
mtflat's Avatar
mtflat
Wheel mounting surface side to side is 61.25"
Wheelbase is noted in the manual pics.
Old Mar 20, 2008 | 05:36 PM
55 dude's Avatar
55 dude
thank you!
Old Mar 20, 2008 | 06:17 PM
55 dude's Avatar
55 dude
keep trying to contact Greatnorthwoods but the site won't let me for some reason? if someone else can contact him have him pm me. thanks
Old Mar 20, 2008 | 06:39 PM
bobj49f2's Avatar
bobj49f2
I sent him an email, hopefully he'll drop in soon.
Old Mar 20, 2008 | 08:23 PM
rcav8or's Avatar
rcav8or
If you use it, SUPPORT IT
Man, oh man!! You DON'T want a 3/4 ton! Especially not an early one...
To save you a lot of grief, where can I pick it up???? Sure would look great alongside my '51 3/4 ton!!!!!
Now, kidding aside, from what I have gleaned here - yes, the f-2 has 8 lugs. You CAN change out the front spindles, to 5-lug, and if you change the rear end, you'll be able to keep the pattern's the same. The frame is basically the same in front, different from the cab back. I'm sure someone will pop in, with the differences, where they pick up the extra length, etc.
I didn't see you mention it - what engine, tranny, etc, does it have in it now?
Good luck with your project...
R
Old Mar 20, 2008 | 08:31 PM
55 dude's Avatar
55 dude
are the 3/4 and 1/2 ton spindles the same other than the lug count. reason being i want to change to disc's using 73-79 truck rotors on front with 5 on 5.5 and change rear to 5 on 5.5 as i have a 59' truck rear to swap in. new steering will be toyota power.
Old Mar 21, 2008 | 08:23 AM
irondragon79's Avatar
irondragon79
Yes the spindles are the same on the F-1 through F-3, so any of the typical upgrades used on the F-1's will work, but you lose the 8 bolt wheel pattern (which is what you want). Your 59' axle should be a direct bolt on, and the toyota power steering would be identical to an F-1 install as well.
Old Mar 21, 2008 | 09:31 AM
Oz52F1's Avatar
Oz52F1
Helpful Guys, huh ??
Sometimes it takes a couple of days, but they give VERY accurate info!
Mark in Japan
Old Mar 21, 2008 | 10:06 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Dude,
The site won't let me PM you either. You can however email me at New_Hampshire_Yankee at Yahoo.com.
Old Mar 21, 2008 | 10:16 AM
55 dude's Avatar
55 dude
what your saying is 48'-60' ford front axles are identical? i was on a site that says the c to c on the kingpins are 3" wider on the 53' up axles could it be a misprint? sure hate to rebuild the 59' axle and find out it was wider and not a "direct bolt-in" it would make thing easier as the truck is 3+ hours away.is the 59' rear a good candidate or should i go with something newer? thanks
Old Mar 21, 2008 | 10:36 AM
irondragon79
I was refering to the rear axle being a direct bolt on, the front axles are differant and are not interchangable as far as i know with 52 and earlier vs 53 newer
Old Mar 21, 2008 | 10:53 AM
rcav8or's Avatar
rcav8or
I think it's easier if you remember, the "First Generation" trucks are '48 - '52. These were denoted by F-1, F-2, all the way to F-8 for the "big boys":
  • F-1: 1/2 ton (4,700 GVWR max)
  • F-2: 3/4 ton (5,700 GVWR max)
  • F-3: Heavy Duty 3/4 ton (6,800 GVWR max)
  • F-3: Parcel Delivery (7,000 GVWR max) & optional rear spring pkg (7,800 GVWR max)
  • F-4: 1 ton (7,500 GVWR max) & optional 1 1/4 ton pkg (10,000 GVWR max)
  • F-5: 1 1/2 ton: Conventional, school bus, and cab over engine (C.O.E.) (10,000-14,500 GVWR)
  • F-6: 2 ton: Conventional, school bus, and C.O.E. (14,000-16,000 GVWR)
  • F-7: Conventional (17,000-19,000 GVWR)
  • F-8: Conventional (20,000-22,000 GVWR)
Then, in 1953, the "Second Generation" came into being, from 1953 to 1956, with the names changed to:
  • F-100: 1/2 ton (5,000 GVWR max)
  • F-110: 1/2 ton (4,000 GVWR max)
  • F-250: 3/4 ton (7,400 GVWR max)
  • F-260: 3/4 ton (4,900 GVWR max)
  • F-350: 1 ton (9,800 GVWR max)
  • F-360: 1 ton (7,700 GVWR max)
  • F-500
  • F-900
Third Generations was 1957 to 1960:
  • F-100 (F10, F11, F14): 1/2 ton (4,000-5,000 GVWR max)
  • F-100 (F18, F19)(4X4): 1/2 ton (4,000-5,600 GVWR max)
  • F-250 (F25, F26): 3/4 ton (4,900-7,400 GVWR max)
  • F-250 (F28, F29)(4X4): 3/4 ton (4,900-7,400 GVWR max)
  • F-350 (F35, F36): 1 ton (7,700-9,800 GVWR max)
  • F-500 (F50, F51), : 1 1/2 ton (10,000-15,000 GVWR max)
So, when you are talking about F-2 spindles being the same as F-1, you have to keep in mind the years. The first generation spindles from an F-1 will work on the F-2. Not so the 2nd generation or later. I think that's where the misunderstanding comes in.
I looked into all this, when I was contemplating making my F-2 an F-1. All in all, it would have been a LOT less work, and a LOT less money to buy an F-1 to begin with than try to make my F-2 an F-1. Of course, the F-2 grew on me, after I decided against changing out the flathead. Now it's all going back original, flathead and granny 4 speed.
The F-2 has a character all it's own...
R
Old Mar 21, 2008 | 11:38 AM
55 dude's Avatar
55 dude
sure do thank everyone so far. as long as i can "bolt on" a 5 lug disc conversion on the stock F-2 spindles that is fine. so i take it 72' and back truck rearends are all good for the swap out back. any info on mounting a master cylinder in the stock location. is this correct the F-1 has 114" wb and F-2 has 122" wb? i was told the stock seat is missing any suggestions as to what bench seat fits nicely in place of the stock seat. thanks
