400 2v+4v heads
Old Mar 20, 2008 | 07:48 AM
OldBlue68's Avatar
OldBlue68
400 2v+4v heads
Alright so i have a question, i currently have a 400 2v, and i was looking to but 4v heads on it, But first me and my friend have been arguing over what the V stands for..from what i understand it is Barrels ,but he says valves if someone could clear that up that would be great. But anyways what would i have to do to get the 4v heads to work correctly on a 2v motor?
Old Mar 20, 2008 | 08:45 AM
acct21's Avatar
acct21
I always understood it to denote the barrel carb on the intake - but that certainly may be wrong. It absolutely does NOT stand for valves - there was never a 4 valve arrangement from Ford for their pushrod engines.
To get the 4V on your engine, you need to locate a 4V intake manifold, as the intake ports on the 4V heads are MUCH larger than the 2V. You will also need to make provisions for the exhaust (for the same reason).
Unless you've got a particular build in mind, you can probably find some great recipes for a 400 here that DON'T involve the 4V heads.
Old Mar 20, 2008 | 09:04 AM
TMI's Avatar
TMI
The "barrels" on a carb are actually a ventrie (spelling??)
hence the "V", more commonly used in the older days.
In the big picture you are correct in your thinking.
Old Mar 20, 2008 | 09:35 AM
OldBlue68's Avatar
OldBlue68
well i already have a edlebrock intake, and sanderson headers that are meant for a 4v cleveland already , so u think it owuld be better to buy a pair of heads then send a pair of the 4v to the shop?
Old Mar 20, 2008 | 10:08 AM
ibleedblue1385's Avatar
ibleedblue1385
The "v" stands for "venturi"
Old Mar 20, 2008 | 10:32 AM
mustang81's Avatar
mustang81
I know the valve on the 4v head are a little bit bigger 2.198-inch intake valves and 1.715-inch exhausts with small chamber.4v head are good to produce torque on the high end. 2v good for low-end torque, 2.050-inch intake and 1.659-inch exhaust with open chamber. Australian head is a mix between the 2:small port with close chamber. Hope this can help.
Old Mar 20, 2008 | 11:04 AM
OldBlue68's Avatar
OldBlue68
i see..im havingtrouble deciding what heads i should go with but thank you for your help, would you guys say aussie would be one of the betters heads for a build
Old Mar 20, 2008 | 11:17 AM
mark a.'s Avatar
mark a.
[QUOTE=OldBlue68]i see..im havingtrouble deciding what heads i should go with but thank you for your help, would you guys say aussie would be one of the betters heads for a build[/QUOTE
Yes thats right & you should get a set of TMI's 0 deck pistons to go with them.
Old Mar 20, 2008 | 11:36 AM
mustang81's Avatar
mustang81
Tim have aussie head and piston
Old Mar 20, 2008 | 12:01 PM
hollenjoe's Avatar
hollenjoe
hmmm I wanna build another 400 but using the 4v heads and try to make it rev really high, i would use 4 bolt main caps a high mid range cam a 750 carb and open headers, mybe some costume made forged rods....
Old Mar 21, 2008 | 01:59 AM
roger dowty's Avatar
roger dowty
what cam hollenjoe? like 230,240 range @050?...mechanic roller? I have a set of 4v closed chamber heads... picked em up a few weeks ago...thinking of putting them on everything but dang they won't reproduce. Have 72 cj with open chamber...was considering using them on that car if i keep it when I'm done fixn it up... a big cam and 11:1 cr is mandatory imo to get the high end force these are capable of.
Old Mar 21, 2008 | 07:40 PM
danlee's Avatar
danlee
Don't forget that you also need spacer plates to use 4V heads on a tall deck 351M/400 block. You still need the 351C-4V intake manifold. The Sanderson headers should work on the 4V heads, but you need adapters for those on 2V heads.
You need a high lift cam to get the maximum flow from 4V heads.
What do you expect from this motor? Lots of power at low RPM, or good power at highway speed, or high RPM power.
Old Mar 26, 2008 | 08:39 AM
hollenjoe's Avatar
hollenjoe
Yep Something in the range, but not exactly a mechanicall (still want to keep it streetable) and yes closed chambers would be great to help keep some what a higher cr, I simulated several mechanical and hydraulic comp grinds with 4v heads and 11:1 cr and the best results are still with a double profile cam (Int dif ext) and a high lift like the xe284h where i got :
torque : 392@2000
max torque : 485@4500
Hp : 496@6000
Not bad.... It estimated a dcr of 8.2:1 wich will need 91 and maybeeee 93 octane
All with a 750cfm carb
Old Mar 26, 2008 | 03:09 PM
hollenjoe's Avatar
hollenjoe
Are this sizes real and exact for 2v and 4v valves?, ive heard too many variations.......
Old Mar 26, 2008 | 03:43 PM
LxMan1's Avatar
LxMan1
No torque with the huge ports on the 4V heads. Will work good in the 3500 to 7500 rpm range.
