fe oil pan question?
Old 03-19-2008, 05:53 PM
boo-yaa138's Avatar
boo-yaa138
boo-yaa138 is offline
Question fe oil pan question?
im about to start the rebuild of my 360 and turn it into a 390. my question is can i get a oil pan with a drain plug in a different location? the drain is on the backside of the sump and when you drian the oil it drips all over the cross member. do anybody make one or did any fe's come with something different?
Old 03-19-2008, 06:36 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
I drilled a hole and welded a nut to the inside on a 300-6 I rebuilt, and have done that to several transmission pans as well. Just be sure to pick a flat area, and clean it well before you begin.
Old 03-19-2008, 07:06 PM
Redmanbob's Avatar
Redmanbob
Redmanbob is offline
I've been considering snagging a 4wd pan and installing it for the same reason. Only I'm not sure it will fit, had a chance to get one for 20.00 at PYP one weekend and passed on it &*()&^&!! didnt even take time to see if it would possibly fit/measure anything at all.. is 20/20
But to solve the oily issues I just bust down a 12pk container and slide it under the pan as a deflection surface of sorts.. works well enough but does take a minute to get ready.
Old 03-19-2008, 07:25 PM
FFR428's Avatar
FFR428
FFR428 is offline
Needsmorecoffee.
I'm guessing you have to drink the 12er before you can use the container as a deflector?? HA!
Old 03-19-2008, 08:18 PM
Redmanbob's Avatar
Redmanbob
Lessu'nz you don't ming fridge bowling showz thats just fine I faind they stand up longer in the case. Keeps the veggies from gettin all bruised. All three of them LOL
Old 03-19-2008, 09:15 PM
f2501967's Avatar
f2501967
f2501967 is offline
ive ran into the same problem when i replace my stock pan with one from milodon. i uses some wax paper, layed it down on crossmember, taping the end of it to the front of oil pan, works good for me. and put a creas in the paper and angled it towards oil catch pan. no mess easy clean up.
just my .01, for my thoughts
Old 03-19-2008, 10:00 PM
dodmort's Avatar
dodmort
dodmort is offline
fram makes these little tube things that you put a bung in the hole. then you screw on this tube which pushes the retainer in and starts the oil draining....it is slow work when oil is cold...( that is when you down the 12 pack) but real clean..they make one for newer cars/trucks to so i also also put a remote oil filter on my 69 so it would not mess the cross mbr..even did it on the svt cobra since there was 0 room to get in there and not make a mess
Old 03-21-2008, 08:52 AM
OrangeJuice's Avatar
OrangeJuice
OrangeJuice is offline
When I change my oil I use a metal tray about 10'' long that is bent up on the sides like a U shape and lay it on the cross member draining towards the front. Works pretty good. Came with the truck from the original owner.
Old 03-22-2008, 11:35 AM
DarkWolf40's Avatar
DarkWolf40
DarkWolf40 is offline
I cut the back end of the oil pan off, welded in some sheet metal to make it longer and added the drain plug in a position it won't hit the crossmember. Got 7 quart capacity now and no mess during an oil change.
Old 03-22-2008, 10:10 PM
baddad457's Avatar
baddad457
baddad457 is offline
You can use any of the FE/FT pans in the 60's and 70's trucks, they all fit, except maybe a Cobra "T" pan.
Old 03-22-2008, 10:31 PM
Redmanbob's Avatar
Redmanbob
thanks for clearing that up.. the hunt is on...
Old 03-24-2008, 02:28 PM
iridium's Avatar
iridium
iridium is offline
I thought that those tube extender things would not work on the FE oil pan becuase where the bolt/drain hole is on the pan it is curved?
alvald83
10-05-2012 11:35 PM
WestG
08-05-2012 01:35 AM
New-retired-man
Oil & Lubrication
11-22-2004 10:01 AM
Goodold71
09-21-2004 04:48 PM
Quick Reply: fe oil pan question?
