oil pan differences
Old Sep 19, 2004 | 03:37 PM
Goodold71's Avatar
Goodold71
oil pan differences
Was there a different oil pan on the 2wd and 4wd truck FE engines?
Old Sep 19, 2004 | 04:04 PM
gtex's Avatar
gtex
I believe so. The 2wd trucks have the front sump and the 4x4s have the rear sump/pickup.
There are few if any high capacity aftermarket pans that fit the 2wds. I've gone to the FT oil pan from the bigger F Series of that generation. It holds about 10 quarts and has a rear pickup that's good for 1/4 mile romps.
Old Sep 19, 2004 | 04:06 PM
Goodold71's Avatar
Goodold71
does anyone like summit or jegs carry rear sump 4x4 pans or should I check the wrecking yards?
Old Sep 19, 2004 | 04:11 PM
gtex's Avatar
gtex
I think the rear sump pans are easier to come by. Check this sites sponsors first, follow the "Parts Shop" link at the upper right.
Check Jegs and Summit, if nothing then check the Canton web site....
http://www.cantonracingproducts.com/
Old Sep 19, 2004 | 09:45 PM
comet's Avatar
comet
Too bad you need it right now because I'm running a tired old 360 that's not worth anything in my '71 4x4 until I can save for a 460 build. I think the oil pan is probably the only thing worth a darn on that motor. The rest is junk.
EDITed :
Oh, and when you get the 4x4 pan, don't forget you need a rear sump pick up for it and the bracket that attaches to one of the main caps. A junk yard may be your best bet.
Old Sep 21, 2004 | 04:48 PM
Goodold71's Avatar
Goodold71
When are you doing the 460? I am expecting my engine to be ready in the next 2 - 3 days.You woulnt happen to know where I can get one would you?I have been to all the local wrecking yards...and nothing.
bkaul
Mar 17, 2015 04:13 PM
PHXCobra
Jan 21, 2014 10:15 AM
FarmerFrank
Feb 20, 2010 09:23 AM
mustang81
Engine Swaps
15
May 5, 2008 07:49 AM
oldhalftons
Dec 3, 2003 06:40 PM
