400 Cam suggestions
Old Jan 15, 2003 | 11:43 PM
Hidome's Avatar
Hidome
400 Cam suggestions
Hey all,
I just had a rude awakening this morning when the machine shop called and said that they could not get the TRW L2466F (8.7/1) pistons. They said they have been discontinued. I wrote Federal Mogul a letter expressing my consern. Anyway, I want my compression. If I would have known this I would have opt'd for the 400 upgrade to get my piston selection, well the crank has already been turned, new flywheel bought and I fell stuck with the 7.9/1 stockers. Does anyone know where to get a set at PLEASE?
Thanks
Old Jan 16, 2003 | 12:42 AM
Ford_Six's Avatar
Ford_Six
400 Cam suggestions
In my piston quest, I did come accross a set of KB pistons, available on their website, www.kb-silvolite.com They are for a Chrysler 392, but it is a 4.0" bore, they are available in .020" and .030" overbores. it is considered a low compression piston, but the compression height is 1.904", vs. the 351m's height of 1.921. Also, the pin is a little larger, so the rod will have to be bored and bushed. From what I know of these engines, there is enough room to have a .020" taller piston in there, and this will bring your compression up to close to your goal. Unfortunately, Silvolite doesn't make an equivalent to these, so you would be stuck with racing parts. Talk to your machine shop, see what they say. I am fairly sure that the pistons will clear the head, but have them measure the deck heigh just to be sure.
Old Jan 16, 2003 | 02:26 AM
Brian S's Avatar
Brian S
400 Cam suggestions
I got some different figures for the pistons.
The 351M is 1.947"
KB's 392 is 1.94
I would definatly look into these. The pin diameter is very close. You will have to add another notch for the intake valve, but if you are running a mild cam it doesn't have to be very big.
Old Jan 16, 2003 | 06:04 AM
D9351's Avatar
D9351
400 Cam suggestions
I used the badgers (there was a long thread on it)(9.x:1, avail .020 and .040 over), but I keep hearing that you can just use a 351 C piston if you just play with bushing diameters. That might give your more choices than just the Chrysler pistons (which sound like they have to be bushed anyway). If you use Chrysler pistons, do you have to change to a starter that laughs at you when cranking?
Old Jan 16, 2003 | 07:24 AM
shazam's Avatar
shazam
400 Cam suggestions
Hehehehehe You made my day with that statement.. Not to often you start your day with a good chuckle....
Old Jan 16, 2003 | 07:38 AM
D9351's Avatar
D9351
400 Cam suggestions
Glad to help, I owe you for advice on several occasions...
Old Jan 16, 2003 | 09:27 AM
Bill_Beyer's Avatar
Bill_Beyer
400 Cam suggestions
Cleveland pistons aren't going to work in his motor. He's building a 351M and the compression height is all wrong for that application. You can only use Cleveland pistons if you're building a 400.
For Hidome, I'd start calling around and seeing if you can locate a set of the TRW pieces which are laying on a shelf somewhere. PAW advertises them, I'd also call Summitt, JEGS, Nothern Auto Parts, etc.
Old Jan 17, 2003 | 08:41 AM
PhordPh250's Avatar
PhordPh250
400 Cam suggestions
The Badger pistons may be unavailible also...Tim Meyer says he can't get them anymore..I got the last set (This is in reference to the long post)
Old Jan 17, 2003 | 09:09 AM
Quantrex's Avatar
Quantrex
400 Cam suggestions
Old Jan 17, 2003 | 11:47 AM
Coondawg's Avatar
Coondawg
400 Cam suggestions
A supplier in Tonawanda, NY just told me that Badger, Ohio Piston and Dynagear is the same. He also said Badger/Ohio is going under and the pistons are only available as off the shelf.
Kyle Wood
Nov 10, 2016 01:30 PM
Macrobb
Oct 12, 2014 02:08 PM
breezesboy
May 12, 2014 11:41 AM
77_F150_4x4
Jul 31, 2013 10:06 PM
beensack
May 30, 2006 10:02 AM
