overheating
Old Jul 11, 2000 | 10:15 PM
77_F150_4x4's Avatar
77_F150_4x4
overheating
Old Jan 14, 2003 | 08:26 PM
JJDDOOGG's Avatar
JJDDOOGG
overheating
Hey guys, I just finished up my 400 rebuild and started it for the first time. My oil pressure at start up was around 75-80 psi at idle. After it warmed idle pressure was 20-25. When the motor is at 2000 rpm the pressure is 50-60.
Is this mormal? I was expecting more oil pressure than that. My 351m when I did a main bearing change only, was higher psi than that. Do 400's usually not have as much oil pressure? I used a reground crank and new bearings and a new oil pump. I plastigauged them too and all was well. I put assembly lube on all bearings and pumped and primed the oil pump.
Thanks, Jaret
Old Jan 14, 2003 | 09:07 PM
grclark351's Avatar
grclark351
overheating
sounds like more than enough to me. what oil is it? standard or hv pump?
Old Jan 14, 2003 | 09:12 PM
JJDDOOGG's Avatar
JJDDOOGG
overheating
[updated:LAST EDITED ON 01-14-03 AT 10:13 PM (EST)]The oil is straight 30 weight castrol heavy duty. What is the best oil weight for break in?
Its probably fine. I was just expecting more. The oil pump is a standard pressure pump.
Thanks, jaret
Old Jan 15, 2003 | 09:52 AM
beartracks's Avatar
beartracks
overheating
That sounds about right to me. The oil can get really hot during breakin and should be changed after the first 20 minutes or so. I prefer 10w40 in winter and 10w50 summer.
Old Jan 17, 2003 | 12:44 AM
jopey's Avatar
jopey
overheating
mine is the same with a stock melling pump.
TMayberry
6.4L Power Stroke Diesel
Sep 15, 2010 10:35 PM
jimkidd
Feb 21, 2006 08:30 PM
kiksomepoo
Offroad & 4x4
Nov 21, 2002 07:40 AM
4x4x4x4
Modular V10 (6.8l)
Apr 16, 2002 10:29 PM
LK
1997 - 2003 F150
Feb 21, 2002 12:44 PM
