2000 kit
Old Mar 18, 2008 | 07:24 PM
JethroF250's Avatar
JethroF250
Question 2000 kit
ok as some of you have probly seen. my dad bought a 2000 f-350 and i'm tryin to do some mods to it. he had the lift takin off of it and i dont want to waste it. is there a way i could put it on my truck? i have a 95 f-250 7.3.
Old Mar 18, 2008 | 07:29 PM
tjbeggs's Avatar
tjbeggs
what size is the lift? The rear spring will fit if you drill out the rear shackle (atleast I think that is what needs to happen) the front springs are too long to go on your truck.
Old Mar 18, 2008 | 07:32 PM
JethroF250's Avatar
JethroF250
i think it might only be a 2 or 4 i'm not sure cause we just got the truck. i hav a 2in leveling kit for mine now but didnt want it yet for that fact of the truck squatin while towing somethin. if its a 2in lift you think it would look fine with a 2in leveling on my truck?
Old Mar 18, 2008 | 07:34 PM
tjbeggs's Avatar
tjbeggs
if its just a 2 inch lift kit it probably just has rear lift blocks but I don't know for sure. What kind of parts did they take off?
Old Mar 18, 2008 | 07:43 PM
JethroF250's Avatar
JethroF250
don't know yet we get the truck 2mro. then i can tell ya. but i just didn't want to not use the kit if its sittin here.
Old Mar 18, 2008 | 07:58 PM
c00nhunterjoe's Avatar
c00nhunterjoe
if you are afraid of yours squatting after the lift you can swap your rear spring block for a 350 rear block and get an extra 2 inches out back
Old Mar 18, 2008 | 08:00 PM
JethroF250's Avatar
JethroF250
thats what wes told me. cause i was thinkin bout the 2 inch leveling with the 350 blocks. the truck levels out now when loaded. i don't want it to squat and with the truck already level before loading i think it might squat more than what i want when loaded
Old Mar 18, 2008 | 08:02 PM
tjbeggs's Avatar
tjbeggs
When I did the leveling kit on my 95 f-250 it sat 1/2 inch higher in the rear but it was too close and looked like it sagged in the rear even without a load. so fi the springs or blocks will work it will be a good move to get 2 inches. With mine I just went 3/4 inch and it was good but more is always better!
