PS Hose
Old Mar 18, 2008 | 11:34 AM
dagren99's Avatar
dagren99
PS Hose
This is a heads up...
Driving my 2000 F250 this am - I lost PS assist & brake booster due to a worn through PS line. Looks like it had been rubbing for quite a while. You bet I'll be checking our 03 when I get home tonight - wish I'd drove the 08 to work this morning!
Check yours - I had a hose rubbing where the steering shaft (from the column/steering wheel) passes by the back of the PS pump. I didn't lose all of the fluid but I'll bet I lost 75% of it. Sprayed !^#$%&#$!%&$#% PS fluid all over the fenderwell, shock, brake caliper & wheel. What a MESS!!!
I wrapped the replacement hose in Nylon spiral wrap to protect it. If you drive on rough roads or off road quite a bit this is a definate must check item.
DG
Old Mar 18, 2008 | 11:51 AM
PaysonPSD's Avatar
PaysonPSD
DG
Thanks for the "heads Up" DG. Going to check it today and buy a length of split plastic loom to cover it.
Old Mar 18, 2008 | 12:12 PM
MTDewX's Avatar
MTDewX
Dam, this Site Rocks. always watching each other back to help one another.
Cheers
Old Mar 18, 2008 | 12:18 PM
PaysonPSD's Avatar
PaysonPSD
PS fluid all over the fenderwell, shock, brake caliper & wheel. What a MESS!!! DG
I know you are probably calling it PS fluid because of it's fuction but to clarify it is ATF fluid.
Edit: Since this is about PS here is a good write up on PS System Flush
http://seven.three.superdutypsd.com/...Steering_Flush
Old Mar 18, 2008 | 12:30 PM
SpringerPop's Avatar
SpringerPop
Mine's not touching, and shows no signs of wear, but DAMN, that's WAAAAAYYYYY too close for comfort!
Mine will be getting some protection, too!
Thanks for the head's up on this.
I posted about a similar problem in this thread:
https://www.ford-trucks.com/forums/5...turn-hose.html
Pop
Old Mar 18, 2008 | 12:33 PM
UP_There's Avatar
UP_There
thanks for sharing your info! I"ll be checking mine out when I get home!
Old Mar 18, 2008 | 12:37 PM
PaysonPSD's Avatar
PaysonPSD
Since this is a PS topic here is a good write up on PS system flush.
Old Mar 18, 2008 | 12:50 PM
BillyBob69's Avatar
BillyBob69
I agree! I just checked mine at lunch. Too close for comfort.
Old Mar 20, 2008 | 10:32 PM
big poppa's Avatar
big poppa
What i did was, get some heater hose cut it about 4 inches long and slice it in the middle, just slip it on,wala. Then checked all other hoses and did the same with other size rubber hose.
Old Mar 24, 2008 | 08:15 AM
dagren99's Avatar
dagren99
Hose
Apparently something in the length/routing of this hose varies from truck to truck - on our 03 F350 it was close but not rubbing. Ended up protecting it anyway just to be safe.
On the 00 it looked like it had been rubbing for some time as the steering column shaft was shiny/burnished in the area that was rubbbing. Amazing how it sprayed out of there @ 60mph - I have fluid all underneath too. Time for a good underbody wash.
DG
