I passed a gasoline station/BANK and there was a fellow pumping e-85 in his older Dodge truck. Could this be used in my 2002 e-150 Triton without any problems?
Thanks Butch001
If you can read this thank a Teacher.
If you can read this in English thank a SOLIDER.
Don't do it unless the vehicle is specifically designated a "flex-fuel vehicle". It won't run right and there are a number of expensive parts you can fry. I'm sure there are quite a few discussions about this in the alternative fuels forum here.
Unless the guy covertered his truck to run on e85, he will regret doing that.
Your 5.4 would run way too lean on e85. Also, the alcohol can damage some components in the, gasoline only, fuel system.
Even if you converted the vehicle to run on e85, which is cheaper, the benefits are not what you think. This is because the BTU content of e85 is significantly less than regular gasoline. Because of this, the engine won't make as much horsepower and your fuel mileage will go down.
In an engine properly designed for E85 (and a conversion to an existing vehicle might not end up being properly designed), you will definitely lose fuel mileage because of the lower BTU content, but E85 has 3-5 more octane than gasoline. So, if the engine is tuned to take advantage of that octane, you can get more power out of it.
Yes, you can make power with alcohol. Its a popular racing fuel because you can run very high octane and thus burn alot more fuel and that makes more power. Yet the engine runs cooler and is less likely to knock and damage itself.
I am very familiar with alcohol as a racing fuel. I have been involved in racing for more than 25 years. And for what its worth the American LeMans series is running a number of its entrants on E85 this year.
On a side note, with all of the current interest in alternative fuels.... Biodiesel is becoming quite popular with some poeple refining their own fuel at home. These people are going to be in for a shock when the IRS nails them for using non-taxed fuel on federal highways.
