Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Electrical Guides
- Spark Plug Wire Reviews
Reviews and comparisons of top products
How good are SplitFire spark plugs????
Hey guys!
I headed to town today and got 6 new Split Fire spark plugs with the V electrode. Have any of you ever tried em and how good are they? Also what is the gap? I knew I saw the number, but I forgot it! Isn't it around .035 or something?
Thanks!
Thanks!
I believe Thomas (Travlnman) has those in his truck. I seem to remember him mentioning he ran them and they did OK.
While I am not sold on the touted benefits, they'd be OK as long as they didn't cause problems.
I prefer to stick with Motorcraft. HOWEVER.....
About a month back I wanted to check my plugs. In so doing, I cracked an insulator. It being Sunday afternoon, I had to run to Wally World and pick up some plugs. I got Autolite copper plugs, gapped them to .054, and they are doing just fine. I know they won't last near as long as Platinum plugs, But, at about $1.25 each, they are cheap.
I plan to go back to Motorcraft Platinum next time, just so I don't have to mess w/ changing them as often.
I have to work tomorrow, so I will give em a test run and report back to you guys. Before I put the new plugs in, the truck was acting like the engine was not firing right and so I decided to end the problem because it was getting annoying. When I took all of the plugs out, two were white and the other four were a nice tan-greyish color. I looked at the two plugs that were white and realized that the gap was too big and melted down the electrode real bad. Ouch!
Now I'm hearing a shrieking sound when I start the engine. What is making the shrieking sound and how do I get rid of it?????
Thank you for any advice!
Did the shrieking sound start right at the time you installed the plugs?
Does it go away after about 15-20 seconds? If so, I'd guess the fan clutch - and would say it's normal.
If it doesn't go away and it started when you installed the plugs, then I'd guess you have something (???) contacting the fan, the belt , or some other rotating device. Or, you knocked a vacuum line off.
BrianA, yes, it started after I installed the plugs. I had my boss look at it and he figured it was a idler pulley going bad (he listened to it with a stethoscope). Would you agree with this or is it the fan clutch? But the sound goes away right after the engine runs for 10 secs.
I test ran the SplitFires and found that the truck pulls much better on hills and accelerates like a hot knife through butter. Smooth and nice-no more bucking! Yay!
Oh and btw, how much would it cost me to replace either the idler pulley or the fan clutch? I just want to get a rough estimate, but the prices for the same parts vary in every state. So, what amount do you have to spend on parts in your state? Also, how hard is it to install the idler pulley? I know I have to take the belt off and a few bolts, but other than that, how straightforward is it?
Thanks!
Thanks!
Thanks!
Thanks!
I owned an Expedition that did the same thing.
I would not worry with it unless you notice your engine temp rising. I think it's normal.
BrianA, I just discovered something real weird-the sound just disappeared! I can't hear it anymore. I mean, it was definitely making that sound but it just disappeared!
I was really surprised.
I'll let you know if it comes back again. When it does come back, I will replace either the idler pulley or the fan clutch, because I don't want to have people come up to me and say, "Why is your truck screaming?" That would be embarrassing!
My parents just bought a '97 Expedition a few weeks ago with 121K on it. It ran great and rides very well. It has the baby 4.6L engine in it and it doesn't make that shrieking sound. Weird......
Anyways, thanks a lot, guys, for all the help you have been! Appreciate it!
I put Bosch plats. in my old Subaru Brat and my wife's Mustang at the same time a couple of years ago, both vehicles developed a stuttering like miss while cruising that did not go away until I pulled the Bosch plugs out ( less than a couple of hundred miles). I wouldn't put Bosch on a lawn mower after that episode. I installed NGK irduim plugs on my 2000 F150 alittle over 5k ago and they work great. I wouldn't wait 100k to change these plugs either or your likely to have alot of trouble removing them( I have been told this because I don't wait that long like I said). The Mustang had 52k and the back two plugs looked pretty bad, covered with a goldish looking deposit, used the autolite copper core on it as that was all I could find. The autolites worked great in the Mustang. My truck I replaced at 30k and the Motorcrafts still looked fairly new.
Originally Posted by ET1
Any comments on Bosch plugs. I plan to replace my Motorcraft plugs.
kdhannink
17
05-09-2013 11:13 PM
donship
Computer Chips & Tuners
02-06-2007 11:28 PM
mudslide
09-28-2004 09:29 AM
