Can't get a blinker working
Old Mar 16, 2008 | 11:23 PM
xjpilot's Avatar
xjpilot
I've figured out that the two metal prongs in the bottom of my front blinker's pigtail are not hitting the bulb, and I can't figure out why. The prongs are getting power, so I just don't know how to get them to stick up any further. Anyone have a suggestion, I like my blinkers.
Old Mar 17, 2008 | 02:14 AM
Sycostang67's Avatar
Sycostang67
I had a similar problem on a 79 F-150. The contact points were getting power but the lights weren't working. Turn out the plastic slots in the socket that hold the bulb were worn and it was letting the bulb slide up enough to lose contact with the prongs. You might try replacing a socket to see if that helps. They are only a few bucks at a parts store.
Old Mar 18, 2008 | 12:54 PM
Holmesuser01's Avatar
Holmesuser01
You might want to double check the ground connection on your current socket before you replace it.
Old Mar 18, 2008 | 01:55 PM
xjpilot's Avatar
xjpilot
the sockets good, both prongs are getting power. As someone mentioned above, the socket is worn out, and the bulb just wobbles around. Oh well, no time to fix it now
rossseger
Nov 3, 2014 02:09 PM
flydaddy
Jan 24, 2014 02:37 PM
dirtyoldrat
Apr 19, 2009 11:41 AM
Rip76
Mar 18, 2007 08:47 AM
