2005 Expedition (Side mirror) blinker....
Old Feb 21, 2007 | 09:48 PM
Rip76's Avatar
Rip76
Wow.
Well, my wife turned on her blinker on the right side, and all she was getting was a fast tick/blink.
The back rear blinker was blinking fast.
The front right, and right side mirror blinkers weren't blinking at all.
I put a new bulb in front, and checked the fuses...
not that...
So I figured it was the side mirror blinker.
Followed the manual, used a torx, and got the screw out...
But I can't pull the freaking lens cover off (under the mirror), and I don't want to break it.
Any suggestions?
Thank you,
mike
Old Feb 21, 2007 | 10:28 PM
FTE Herman's Avatar
FTE Herman
Welcome RIP! I don't know the specific answer but one of the new model owners will probably jump in and answer right quick.
Old Feb 22, 2007 | 07:47 AM
Rip76's Avatar
Rip76
Thank you...
Yeah, I'm sure that lens "pops" off, but man it felt like I was going to break it.
Old Feb 22, 2007 | 10:55 AM
Rip76's Avatar
Rip76
just wondering...
on the blinker issue... I know it used to be this way... but, is the light that is out the one that has a fast blink?
thanks
Old Mar 17, 2007 | 06:12 PM
corvettej's Avatar
corvettej
Trailering
Push the mirror forward while looking from below until the len clear the catch, push in slightly, then pull down, replace bulb and assembly by reverse steps.
Old Mar 18, 2007 | 08:47 AM
whotnow's Avatar
whotnow
The mirror would not cause the fast blink. It is a low wattage bulb. The front or rear are higher wattage and would cause the fast blink if missing/blown. You said front and mirror. Kinda funny they went out at the same time. Since you tried a new bulb in the front and that didn't work, it may be time for a new multi-funtion switch. Time to start tracing wires back to the switch.
rossseger
Nov 3, 2014 02:09 PM
will32_
24
Sep 28, 2014 10:18 PM
balingwire
Dec 6, 2009 07:57 PM
the tank
Feb 28, 2005 12:16 PM
mrsmom298
Electrical Systems/Wiring
Jan 8, 2004 11:07 AM
