Sponsored by: Real Truck
integrated trailer controll
Old Mar 23, 2008 | 04:27 PM
Jakesrodshop's Avatar
Jakesrodshop
big green, thanks, i am checking it out today, anyone have the fuse layouts and description my truck did not come with a manual, i hate people who take manuals out of the truck
let me know thanks alot
jake
Old Mar 23, 2008 | 04:43 PM
Jakesrodshop
found a few under the dash that were missing, without a diagram i just had truck off and tried one at a time then checked trailer plug for power and nothing, am i assumming correctly that the top right side slot is for 12 volt power in the round receptacle on truck? please let me know
jake
Old Mar 23, 2008 | 04:49 PM
Big Green Truck's Avatar
Big Green Truck
Sorry, Jake.....I'm visiting about 1000 miles from my truck, but look here for a wiring diagram: http://www.etrailer.com/faq_wiring.aspx
Gordon
Old Mar 23, 2008 | 05:02 PM
Jakesrodshop
killer site
Ford Fleet - Maintenance - Owner Manuals
manuals for any ford around, found a 20 amp dual fuse gone which was not bringing 12 volts to the rear trailer plug, thanks alot man.
jake
Old Mar 23, 2008 | 08:17 PM
redford's Avatar
redford
FTE Leadership Emeritus
Originally Posted by Jakesrodshop
my 2005 when i plug the trailer in does not charge the trailer battery or give power to the dc lights in the trailer, my 01 f250 powered everything, i did not get the manual when i got the 05 in the fall it has 28k on it and i just wondered if it were a fuse or relay i needed to install to get 12 volts to trailer battery and lights? i have to imagine all 7 slots are used in the connector. let me know,.
thanks again
jake
Jake, one thing to keep in mind is that the +12V line is only hot when the engine is running. If the engine is off the line will have no power.
Old Mar 23, 2008 | 08:21 PM
Jakesrodshop
redford are you sure? could of swarn i checked it today with engine off, maybe not, i will check it, then i need wire diagram to find wire in engine bay so i can get 12 volts to it when key is on.
jake
Old Mar 23, 2008 | 08:35 PM
redford's Avatar
redford
Yea, I am sure....at least on my '07.
Old Mar 23, 2008 | 09:25 PM
Jakesrodshop
i will check it, no biggie if so, most of the time i need the lights it will be hooked to truck running as its a 44 ft enclosed goose neck car trailer
old five string
All Things Towing
May 28, 2013 07:33 PM
brkncly
6.4L Power Stroke Diesel
Oct 25, 2012 01:18 PM
Scottbel
Jul 8, 2009 08:16 PM
50F2
Dec 30, 2004 11:48 PM
