Fuel Pump/Code Problem
Old Mar 16, 2008 | 08:15 PM
Ford88truck's Avatar
Ford88truck
I have a 1988 Ford F150 with a 302. Drove it home the other night and it ran fine, next morning it would not start. It cranked fine but would not fire. I checked and I had spark. No fuel pressure at the rail and I do not hear the pumps running when the key is on. I pulled a code of 96 "fule pump secondary circuit fault/high speed relay open". I replaced the fuel pump relay but this did not help. I also checked the crash switch and it is OK. Any suggestions?
Old Mar 17, 2008 | 12:33 AM
Animalistic's Avatar
Animalistic
Not too sure as I have not had this problem yet but did you check the fuses? I am sure others with more experience will chime in. Good luck.
bdford.fl
1997 - 2003 F150
Aug 9, 2011 12:10 PM
Ed_B1
1978 - 1996 Big Bronco
15
Jul 14, 2011 06:39 PM
chipster6
1997 - 2003 F150
Jan 3, 2007 10:55 PM
nova801428
1983 - 2012 Ranger & B-Series
Dec 13, 2006 09:29 AM
BryanBe
Aerostar
Jun 30, 2002 11:58 AM
