Sponsored by: Real Truck
Chafing concern?
Old Mar 16, 2008 | 06:18 PM
FORDSDOWNER's Avatar
FORDSDOWNER
Chafing concern?
What do you guys think. Something to worry about? I've felt all around that plastic wire casing and don't feel any abrasions.
Old Mar 16, 2008 | 06:29 PM
62rag's Avatar
62rag
Put a plastic or rubber bolt cap/cover over it, or zip tie the wires up. Then you wouldn't have to worry about it.....
Actually these are called vacuum caps.
Old Mar 16, 2008 | 06:33 PM
FORDSDOWNER
Oh yea, got plenty of those. Excellent for plugging carbs and what not, need to get some a little bigger though.
has this been an issue with some of our forum buddies?
Old Mar 16, 2008 | 06:44 PM
skoveng's Avatar
skoveng
Cut yourself a piece of rubber fuel line and slide it over the shock stud.
Old Mar 16, 2008 | 07:07 PM
PSD4ME's Avatar
PSD4ME
Fuel line is great, I use it on lots of things I don't what to chafe. If you cut a length of hose the same I.D. as your cable then slit it open in a spiral pattern, mabey 1 turn per inch, then wrap that on the cable, you will be surprised how much abuse it will take.
Old Mar 16, 2008 | 07:33 PM
FORDSDOWNER
Great. Thanks.
propellerhead
15
Apr 25, 2017 12:28 PM
Raleigh1
1978 - 1996 Big Bronco
682
Mar 18, 2016 01:29 PM
1andonlywhitie
May 11, 2012 07:57 AM
postoak99
1997 - 2003 F150
Mar 5, 2011 11:05 AM
intensecaraudio
Aerostar
Jan 1, 2008 03:01 AM
