Would anyone know where I can order the push on type electrical connectors used on the oil pressure sending unit, Start relay etc.. NAPA has one size which fit our temp sensor but they're too small for everything else.
I think the diameter is about 3/16". For the time being I'll use a regular crimp on pin connector.
Thanks
Dan
That's what we ended up using. That wire was toast! What ever twist it may have had, it was gone. Now we can work on the ignition wiring. For the Duraspark I can't tap into the pins at the ignition switch, so we'll probably solder it on just after the switch connector or plice into the wire that is already pigtailed off the same pin in the switch.
Thanks again.
Thanks
Dan
