door ajar light
Old Mar 16, 2008 | 12:34 PM
silver05fx4's Avatar
silver05fx4
door ajar light
well to day while driving my door ajar light came on while i have already be driving for 20 mins ..so i open the door closed when off for about a minute then it would come off and on every 30 seconds makeing the chime noise to tell you the door is open...when it was closed ..i had issue with the door before like when its colded and u turn the truck off open the door dome light and radio will stay on ....
well if anyone has any clue let me know ...b/c i know when i take it to the dealer their just goin to tell me they can't find anything wrong
Old Mar 16, 2008 | 07:34 PM
VFR_Man's Avatar
VFR_Man
I would say you have a sticky door ajar switch, but they usually act up right after opening/closing a door, not 20 minutes afterward, so that aspect is a bit odd.
The switches are located on the lock mechanism in the door, and if they're like the ones in my '95 Ranger, they can be removed and cleaned up, but I don't think they're terribly expensive (<$20 each) if you just wanted to replace them too.
Looking at my '07 wiring diagram, the door ajar switches complete a circuit to ground when the door is open, so an abraded switch wire in the door may produce the symptoms you describe too.
Old Mar 17, 2008 | 08:29 AM
bwep's Avatar
bwep
Door ajar
I had similar problem door ajar light would not shut off. Also at the same time door lock would not function ether. According to repair order it says they replaced vehicle security module behind rear seat. I did have the third brake light leak earlier so maybe water got in the module. Hope this helps BWEP
Old Mar 17, 2008 | 08:44 AM
f-150 on 22's's Avatar
f-150 on 22's
I had that problem on my 98 f-150 and all I did to fix the situation was to spray some wd40 into my lock mechanism on the door.
Old Mar 17, 2008 | 04:08 PM
silver05fx4
well i have to try somthing ...but it hasn't done it since sunday
Old Aug 12, 2008 | 12:01 PM
wacarte's Avatar
wacarte
Door Ajar Light
I have a '06 F-150 that had the same (or similar) problem, door ajar light on, dome and cargo lights would not turn off, and the power door locks would not work (the remote still did). I tried the WD-40 trick (it worked on my '98) to no avail. I disconnected the battery for about 30 minutes and when I re-connected it everything worked normally.
Old Aug 12, 2008 | 09:04 PM
mercman86's Avatar
mercman86
same thing happened to the taurus. tried every kind of lubricant i could find, but it would sill happen, even after the door was long closed, somtimes 20-30 mins after shutting the door. I had the replace the swich which involved removing the entire latch assembly out of the door! (what a pain!) but im glad i did cause the switch would not pop out all the way and would stick and slowly work its way up to complete the circuit. thats why it would happen even after the door was closed for a while. the switch was only 9 bucks from the local dealer.
dirgio
Jan 26, 2011 05:19 PM
hotwheel_2000
1983 - 2012 Ranger & B-Series
Dec 17, 2006 01:16 PM
mach2race
Jun 8, 2006 08:33 PM
TrakMasta
Aerostar
Mar 25, 2006 09:40 PM
nymets78
Sep 11, 2005 06:28 PM
