Door Ajar
Old Dec 12, 2006 | 10:21 PM
hotwheel_2000's Avatar
hotwheel_2000
Door Ajar
Ok this one is driving me nuts and it has only been like an hour since i noticed it. I was leaving my friends house earlier tonight when i noticed my cab lights and the door ajar light were staying on even after both doors were closed. I slammed both doors a few times with no change. I gave up and headed home and about 30 seconds down the road the lights clicked off. After i got home i tried opening and closing the doors with the keys in the ignition and the little ding alarm would not shut off even with the doors closed for about thirty seconds. I am very anoyed with stuff like this on my cars and i just want to know where to start on this one. It's a 1996 XLT 2wd.
Thanks- Cam
Old Dec 12, 2006 | 10:42 PM
rangerfan's Avatar
rangerfan
Try spraying WD-40 on the little button on your door jam. It would be the easiest and cheapest place to start.
Old Dec 12, 2006 | 11:10 PM
pawpaw's Avatar
pawpaw
Look in the "Tech Info" thread, atop this forums main page & scroll down to the "dome light/door ajar" link.
Also other good reads on problems & fixes there.
Let us know how it goes.
Old Dec 13, 2006 | 06:39 AM
Bob Ayers's Avatar
Bob Ayers
There isn't a "little button" on the door jam. The switch is mounted on the door latch in the door. Just spray the door latch generously with WD-40, then open/close the door several times, and this should free up the switch.
Old Dec 13, 2006 | 08:15 AM
rellik74's Avatar
rellik74
YEP I just did mine a couple of days a go, seems to happen every couple of years
Old Dec 13, 2006 | 02:06 PM
hotwheel_2000
Thanks guys, WD-40 did the trick.
Old Dec 16, 2006 | 07:04 AM
97ranger xlt's Avatar
97ranger xlt
after i did the wd-40 thing i sprayed the latch with white lithium grease.it seems to be keeping the light on the dash out..
Old Dec 16, 2006 | 07:10 AM
rangerfan's Avatar
rangerfan
Sorry for mispeaking The Great Obi-Wan Kenobi
Old Dec 16, 2006 | 10:56 AM
rubydist's Avatar
rubydist
lol That was pretty funny for 6am on a Saturday!
Old Dec 17, 2006 | 09:08 AM
Alan D.'s Avatar
Alan D.
I tried this trick on my truck numberous times before giving up and disconnecting the sensor wire. i must have disoncetted on too many wires though. not my alarm doesn't work that tells me that i left my keys in or that my lights are on.
Old Dec 17, 2006 | 01:16 PM
HomerWinzlow's Avatar
HomerWinzlow
That is because you disconnected the door ajar switch, which activates the dome lamps when you open the door, but also tells the GEM that your door is open so the GEM will not activate the chime to let you know you left the keys in the ignition or the lamps on. You can try to take the ajar switch out and clean it thoroughly or replace it.
sbappleg8
15
Aug 2, 2017 11:45 AM
WhiteBeast97
1997 - 2003 F150
Jan 13, 2007 07:18 PM
mach2race
Jun 8, 2006 08:33 PM
3.0 Ranger
May 25, 2006 11:18 PM
