Aerostar Ford Aerostar
"door ajar" buzzer turning on randomly...
Old Mar 22, 2006 | 11:55 AM
TrakMasta's Avatar
TrakMasta
Hello! In my '93 AWD extended Ford Aerostar, the "door ajar" buzzer and dash light turn on when all doors are properly closed. This happens while driving and usually when going over a bump. The dome light does NOT come on, as it would when a door is actually ajar or open. Any thoughts on how to fix this annoyance would be greatly appreciated! Thank you!
Old Mar 22, 2006 | 12:02 PM
bertha66's Avatar
bertha66
Most likely the sider door, you can clean the contacts, or if it is like my van, I have a worn wheel and the door is cocked alittle and not making good contact.
Old Mar 22, 2006 | 12:27 PM
krankshaft's Avatar
krankshaft
On my Aero the buzzer only sounds when the drivers side door is ajar and the key is inserted into the ignition.
Unless your Aero is different try closing all the doors inserting the key and pressing the driver side door switch by hand and see if the light goes off.
Old Mar 23, 2006 | 12:49 AM
TitleSeventeen's Avatar
TitleSeventeen
last van that we had that did that, had the contacts very worn, i got a small piece of wire and ran it between the top 2 contacts on the B pillar for the sliding door, no more door-ajar light.
Old Mar 23, 2006 | 01:22 AM
krankshaft's Avatar
krankshaft
I am very curious I know that there is a switch for the sliding door isn't that what triggers the door ajar light?
If not where are these contacts?
Old Mar 23, 2006 | 01:55 AM
Pablo-UA's Avatar
Pablo-UA
On the door and on the body! 4 contacts!
Old Mar 23, 2006 | 06:03 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
…..See you on the boards.
Old Mar 23, 2006 | 11:45 PM
DaveMac2Vans's Avatar
DaveMac2Vans
I had a similar issue once, when the chime would sound off while I was going down the road. I finally used a small piece of adhesive foam weatherstrip where the door light switch contacted the door (driver's door, in this case) and it stopped it. I guess it was just enough wear so the door was out of adjustment.
Old Mar 24, 2006 | 07:07 AM
TrakMasta's Avatar
TrakMasta
Awesome, thank you all for the tips and ideas! I will be looking at it this weekend. :-)
Old Mar 24, 2006 | 01:53 PM
TitleSeventeen
yes, there are 4 contacts IF you have power locks, other wise theres only 2, those being the topmost ones for the door ajar light.
Old Mar 25, 2006 | 09:40 PM
FordBoypete's Avatar
FordBoypete
On my '93 XLTN any door not shut properly will trigger Door Ajar warning lamp. Unfortunately my Peizo Buzzer fell out & disappeared one day in a lake. . . .
Back to the original querey, I concur dirty Contacts on the multi Switch of the slider, or "B" Pillar will cause it.
1 culprit that wreaked havoc is hand lotion from people grabbing the place where the switch contacts are located. My daughter played soccer & we carried 1/2 the team! Lots of Hand lotion there!
FBp
sbappleg8
1983 - 2012 Ranger & B-Series
15
Aug 2, 2017 11:45 AM
Canadiancowboy
Feb 9, 2017 08:07 AM
Ford-Muscle
13
Feb 13, 2016 06:09 PM
lennell
New Member Introductions
Aug 21, 2008 09:28 PM
Jan 3, 2003 09:58 PM
