power steering leak
Old Mar 16, 2008 | 12:31 PM
Mike in Ohio's Avatar
Mike in Ohio
power steering leak
I've got to replace a power steering hose on my 69 pickup. Do I have to bleed it after I replace the hose, or will it work the air out by itself? Also the part number on the steering box is c6ar 3580-a is this original? I ask because nothing else on the truck is. Thanks alot, Mike
Old Mar 16, 2008 | 12:33 PM
rob188's Avatar
rob188
no i don't think that would be the original i think most of the original parts for that year are obsolete, i'm not sure if you would have to bleed it after installing but it wouldn't hurt to.
Old Mar 16, 2008 | 02:08 PM
blue68f100's Avatar
blue68f100
If it the return side NO. Put the pressure side will require you to move the steering wheel lock to lock slowly, to purge the air out.
Old Mar 16, 2008 | 02:51 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
That's not a part number, it's a Ford ID engineering number.
And...it's only the ID number for that exact part. ID # C6AR-3580-A > > Ford part number C5AZ-3580-F .. Sector Shaft Housing Cover. It's not the ID number for the gearbox.
You have Ford-Saginaw power steering in your 1969.
That's fortunate, because some 1969's (and all 1966/68's) have the crappy Bendix system. The Bendix system uses a different sector shaft housing cover, than the Ford-Saginaw type uses.
There are three different types of P/S hoses, because they are engine specific.
C9TZ-3A719-G .. P/S Pressure Hose ~ 240/300 I-6.
D0TZ-3A719-A .. P/S Pressure Hose ~ 360/390
C9TZ-3A719-J .. P/S Pressure Hose ~ 302
Old Mar 16, 2008 | 03:35 PM
Mike in Ohio
Thanks to all you guys I got it fixed, just came in the house. I turned the wheel slowly lock to lock like blue said till the fluid quit going down. I'll keep an eye on it for a while though. Thanks for the ID on the steering box numberdummy. This truck has a 460 in it and all sorts of things that weren't available in 69 so sometimes I have a hard time getting parts because I don't know what year the part I wnat is from.
Thanks again, Mike
Old Mar 16, 2008 | 03:59 PM
NumberDummy
Thanks again, Mike
The seals kits for the gearbox are the same from 1969 thru (at least) 1996 on F100/350's, and are easily found because the 1965/1991 Galaxie/LTD/Crown Vic and other cars used the same ones.
F1AZ-3E502-A .. Input Shaft Seal Kit
D7AZ-3E501-A .. Sector Shaft Seal Kit
mazdazoomzoomtruck
Sep 12, 2010 01:53 AM
m000996
Apr 10, 2010 12:03 PM
1Saint
13
Nov 11, 2009 04:36 PM
WILDMAN_Stroker*7.3
Aug 2, 2009 10:37 AM
wjawill
1978 - 1996 Big Bronco
Nov 8, 2004 02:44 PM
