1978 - 1996 Big Bronco
Power steering
Old Nov 7, 2004 | 06:45 PM
wjawill's Avatar
wjawill
Power steering
I need to replace the return hose on the power steering. Can I just replace it with a hose long enough to reach from the steering box to the pump? Why is the stock one so long? It is on a 94 302 auto.
Thanks
Old Nov 7, 2004 | 08:08 PM
tom2131968's Avatar
tom2131968
The length isn't critical and you can use transmission line instead to save some bucks.
Tom T
Old Nov 8, 2004 | 06:12 AM
wjawill's Avatar
wjawill
On mine the return line goes from the stearing box down to the frame then zigzags along the frame like three times then goes to the resorvoir. This can't be just for decoration can it?
Old Nov 8, 2004 | 02:44 PM
greystreak92's Avatar
greystreak92
The high pressure line has to be a high pressure line with the necessary fittings. The low pressure line needs to be connected to the factory P/S fluid cooler to aid in cooling the fluid and keeping it from losing viscosity and cavitating the P/S pump. The metal coil of return (low pressure) line that wraps across the lower crossmember of the frame a couple of times is the factory P/S fluid cooler.
mazdazoomzoomtruck
Sep 12, 2010 01:53 AM
1Saint
13
Nov 11, 2009 04:36 PM
78COBRAII
Feb 22, 2006 12:51 AM
Lead_Foot
May 30, 2005 01:13 AM
