Power Steering
Old Nov 8, 2009 | 08:55 PM
1Saint's Avatar
1Saint
Power Steering
Developed a leak in my power steering. The truck is an "87". I think is leaking from the pressure hose at or near the steering box. Is it possible to replace the hose without removing the pump?
Old Nov 8, 2009 | 09:18 PM
symonds86's Avatar
symonds86
yes it is, sometimes its a bit of a pain starting the line nuts but patients and you can do it
Old Nov 8, 2009 | 09:36 PM
87crewdually's Avatar
87crewdually
If I remember right the fittings are sealed with an O-ring not compression like you may expect. The o-ring goes on the end of the line then you insert the line and tighten the fitting nut. You may just need to replace the oring.
Old Nov 8, 2009 | 10:31 PM
Dave Sponaugle's Avatar
Dave Sponaugle
O rings on the pressure line on both ends.
Old Nov 9, 2009 | 08:53 AM
1Saint's Avatar
1Saint
Can I just pick up O rings at the hardware store or do I need to be concerned that the power stering fluid will eat the up?
Old Nov 9, 2009 | 04:35 PM
symonds86's Avatar
symonds86
hardware store ones shuld work, but if its the hose and you have to buy a new one it will come with new o rings, i donno the size but they are little guys
Old Nov 9, 2009 | 07:29 PM
Kleenax's Avatar
Kleenax
Power Steering Pressure side O-Rings
So Dave;
I am looking at this same fix; happen know know where to find out what size O-rings that are required for this fix?
Old Nov 9, 2009 | 09:12 PM
symonds86's Avatar
symonds86
my local parts store would let take one from new line they have instock and match it up for me. try that
Old Nov 9, 2009 | 09:19 PM
Dave Sponaugle
With a caliper you can measure the tube just above the fitting and get the line size.
That measurement would be the inside ID of the O ring you need.
From memory the O ring thickness is about 1/8".
I think I have an old power steering line up at the garage, I will walk up and see if I can find it.
Old Nov 10, 2009 | 04:09 PM
Happyreefer's Avatar
Happyreefer
When I replace mine, I found this at Carquest. I only had 1 side on my high pressure side that needed it. they were small nylon washers that could not be replace with a rubber o-ring.
part #82540 from carquest.
Old Nov 10, 2009 | 07:58 PM
Dave Sponaugle
That is not the style of hose I have, and I don't know where the old ones I kept as spares went.
Sharing a garage with your son has it's ups and downs.
Things never stay where you put them.
Old Nov 10, 2009 | 09:07 PM
1Saint's Avatar
1Saint
Thanks anyhow Dave. I know how that is. Better yet, recently my wife decided to organize the garage. I still can't find ****!
Old Nov 11, 2009 | 08:11 AM
WEST AUSSIE 94 250's Avatar
WEST AUSSIE 94 250
Sheds should be WIFE FREE ZONES! Secret mens stuff goes on in there.
Old Nov 11, 2009 | 04:36 PM
symonds86's Avatar
symonds86
lol absolutely, i jst wich a had a garage with a door tall enugh to get my truck in, who builds a 30x30 2 car garage with 10ft ceilings with two 7 foot doors? boggles my mind some days
89danford
Feb 17, 2014 04:35 PM
99F-350CrewCab
Jul 7, 2011 10:11 AM
castledrummer
May 2, 2007 02:59 PM
dfisher1
May 22, 2002 11:30 PM
