i dont want just wheelin pics, just put up some pics of what ya got so we can all see it, i hate going to everybodys gallery just to see what yall have
basically stock 97, only on 33/11.5 right now, when i need new tires ill crank the torsion bars some to clear 34/12.5, 4.6, may not be exactly as bad **** as some of yalls rigs but its what i have to play with for now and hope i dont mess anything up to bad till i can find a cheap 73-79 to play with
Bessie -79 F150 4wd 300-6 Np435 205 3.50 gears 33" Wild countrys Frame off resto completed in Sept 06
04 F250 V10 superchip k&n tube deal cobra throttle body
1960 ****** CJ5 144" I-4 3spd T-90 factory twin sticked T-case factory 5.38 gears and 31" tires SCREAMS at 35mph. AKA get drunk mobile! Burns 2qts of oil every 5 gal of gas. Mild 302 one day.
Old pic, truck is now hot rod flat black, diff is welded, bumper is different, new toolbox, and some work that cant be seen in pics anyhow. 2wd on 33s with ONLY 3" of lift no trimming. No sway bars, stock suspension is very flexy with no sway bars btw. RTI score of like 1million. BWAAHHHAAAAA.
Very crappy pic of my 4wd. This is like 2 weeks after I got it. Looks alot different now esp, internally. 38.5" Boggers. 5.13's and built 4.GO. With boost coming soon. FL headers, 3"duals, xpipe, turndowns, single chamber flows, upgraded d-shafts,hybrid front axle, miller lockers, stock t-case, rear disc conv. soon, hood scoops are now functional now, with sheet metal plenum. I could type all nite. PM me for more info or if you want cam specs for a nasty cam for the 4.0 OHV.
