best welder for doing body work
Originally Posted by MBDiagMan
I'm glad you told me that .030 is too thick for sheet metal. I have welded in probably a couple of dozen patch panels with .030 and have had no problems whatsoever. Maybe you need to do a little more experimenting in setting up your welder.
Personally I can use .30 or .23 and I keep the .30 in my welder because I tend to weld heavier steel for my projects.
No reason to get snotty or take it personal. JMO
Originally Posted by GwizRC
The Miller 135 is ok but I would recomend the 180 (more verastile for thicker jobs). .23 for Body is much cleaner and easier to use. .30 is too thick for sheet metal.
When welding sheet metal, don't let it get hot! use a wet rag on the area arround the weld to keep it from warping.
Okay, since your'e calling me "snotty," I'll get snotty. You're right, .30 or even .23 would be too large for sheet metal. Almost a 1/3 of an inch or almost 1/4 of an inch diameter wire would indeed be quite a bit too large. Maybe you should examine your mathematics. I was referring to .030.
Not only that but you stated ".30 is too thick for sheet metal." You didn't say that it would work, or that you even use it, you implied that it just flat won't work.
BTW. You should not have to use a wet rag around the welds to keep it cool enough. You simply bounce around, to allow heat to dissipate at each weld.
It is very easy to misunderstand the written word. When reading someones writing, you see no body language, or hear no tone of voice. If I came across "SNOTTY" I apologize. It might be easier to just stand corrected and move on.
You are correct about my miss typing the wire size. But I still say that .030 is TOO thick for sheetmetal. I use it out of laziness because I only weld sheet metal 10-15% of the time. I think that if you were to set up your welder correctly with both .030 and .023 and test weld two peices of sheet metal together, you will find that the .023 gives you a better outcome with less heat and less grinding.
After "examining my mathematics", I found that I am not retentive enough to notice the typo and know that most people will know what I meant. I will "stand corrected" and move on to a less snotty post.
65fordguy
13
03-21-2008 06:17 AM
