Sponsored by: Real Truck
3/4 or 1 ton?
Old Mar 15, 2008 | 11:40 PM
'94Nichols's Avatar
'94Nichols
I could get it myself, but my parents have realy good credit, I have none, plus they are talking like they are going to pay half of it. I won't be using it for much hauling, just towing my bronco to mudruns through college, but i plan on keeping it when i go back to farming
Old Mar 16, 2008 | 03:03 AM
banditsdaddy's Avatar
banditsdaddy
When I bought my 2006 F350 SRW 4X4 PSD to pull my 5th wheel camper it was $300 more than the comparably equiped F250 sitting next to it on the dealers lot. Later we bought the 5th wheel and the pin weight with the trailer loaded is 3000 lbs. Glad I went for the F350 as it handles the weight well. The only problem I ran into was the height of the bed and we wound up changing the 4" blocks to the F250 2" blocks. That leveled out the 5th wheel and it really made the truck look more level without the trailer.
Old Mar 16, 2008 | 05:49 AM
svt2205's Avatar
svt2205
People mentioned insurance concerns and zoning related issues. Make sure you understand what, if any, restrictions your states DMV places on registering and operating your truck if it has a GVWR over 10,000 pounds. Some states will hit you up for fuel taxes and other fee's if the trucks GVWR is over this limit. Most F350's today seem to be over this too.
Just another thing to consider.
Old Mar 16, 2008 | 09:52 AM
SpringerPop's Avatar
SpringerPop
If you're looking at an earlier-00's F-350 SRW, the GVWR is 9900 lbs. Under 10,000, for a reason, I guess. Dually's are higher, and you may take a hit. Dunno about Kansas.
Pop
Old Mar 16, 2008 | 03:07 PM
'94Nichols's Avatar
'94Nichols
i just want a srw super duty. i want to lift it eventually, but i think i'll try to find an F.350 for now, because it already sits higher.
Old Mar 16, 2008 | 05:20 PM
dd6464's Avatar
dd6464
'05 F350 SRW is 10,800 GVW. Bilstein leveling kit on a F350 is very simple and easy way to look lifted without any special parts.
Old Mar 16, 2008 | 06:03 PM
PSD4ME's Avatar
PSD4ME
Not sure but the 350 might ride a little stiffer due to the heavier springs.............
Old Mar 16, 2008 | 06:11 PM
MeyerzF350's Avatar
MeyerzF350
Same here, but I never thought of changing the blocks. The 5er still sits 1/2" higher in the front when towing. I might have to try that so I am completely level.
Old Mar 16, 2008 | 06:34 PM
SpringerPop
In the OP's sig line it says he wants a 2000-ish with a 7.3. That would limit it to 1999 to early 2003. He also said he wanted an SRW. Those trucks all had the same springs, F250 and F-350.
The difference between the F-250 and F-350 for those years:
1. A four-inch spacer between the rear axle pads and the springs instead of a 2-1/2-inch. Maybe longer u-bolts here, too, but of that I am not sure. Could even be a longer brake flex hose, but again, I'm not sure.
2. Different fender and tailgate badges.
3. Different numbers on the pillar sticker, indicating a different GVWR.
4. Longer rear shocks.
Das' all.
Pop
Old Mar 16, 2008 | 08:28 PM
unrulee's Avatar
unrulee
If you decide to do it I want to buy your F350 blocks, to raise the rear of my F250........it's a strange world !!!
Old Mar 16, 2008 | 08:48 PM
redford's Avatar
redford
FTE Leadership Emeritus
Originally Posted by jdecker88
If you are not going with a dually F-350 then the trucks vary just a little bit. If you are not going to do any heavy towing and really just getting a truck to build and play with you just need a 250.
An F-350 SRW isn't rated to tow any more weight than an F-250. The Ford towing guides do not even differentiate between the F-250 and the F-350 SRW when stating max hauling weights. It's all one column.
The only advantage in buying an F-350 SRW is it will haul a larger load. This extra hauling capacity may come in handy when towing (pin or tongue weight counts as cargo weight) but the F-350 is not rated to tow any more weight than the same truck as an F-250.
As noted, the extra height of the bed can cause problems with 5th wheel towing, the bed may be too high.
78ecf250cs
Oct 4, 2010 09:35 PM
79 f-150 guy
30
Jun 25, 2010 01:22 PM
10bands
Jun 17, 2007 02:49 PM
rusty70f100
General Automotive Discussion
30
Feb 2, 2007 07:55 PM
appleboy
Feb 24, 2003 07:16 PM
