Power valve on carb
Old Mar 14, 2008 | 07:47 PM
Mike's 77's Avatar
Mike's 77
Power valve on carb
Does anyone know how or why the power valve on my holley 2 barrel keeps blowing? So far I'm on the second or third one and I've had the truck for over a year. Is it something on the carb or just a couple defective valves or something else?
Old Mar 14, 2008 | 07:48 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
How is your choke and timing set?
Old Mar 14, 2008 | 08:09 PM
mhg's Avatar
mhg
if your engine back fires or just spits back after turning off
it will blow
I have seen blow out preventers advertised
not sure where but I would start at jegs
also you may need to change to a differant rate on the power valve
Old Mar 14, 2008 | 08:17 PM
bigblockford_390's Avatar
bigblockford_390
I vote on the backfire as the problem. Any good parts house will have the kit, it comes with a drill bit and the little check valve to install in one of the vacuum ports on the bottom of the carb.
Jeff
Old Mar 15, 2008 | 02:06 AM
Mike's 77's Avatar
Mike's 77
Ya usually if I romp on the gas in a parking lot showing off it backfires a little bit lol. How hard is the preventer to install and about how much does it cost?
Old Mar 15, 2008 | 05:42 AM
chrono4's Avatar
chrono4
Rather than just covering up the symptoms of the problem, you could more than likely fix it for free or cheap. If it backfires when you WOT it, I would look towards your base timing, and the setup of the accelerator pump. If either of these aren't adjusted right, it will cause a backfire, and lack of power, or hard starting in the case of the timing.
Old Mar 23, 2008 | 12:27 PM
Mike's 77's Avatar
Mike's 77
So how would I go about checking all these?? I'm not real mechanical lol.
Old Mar 23, 2008 | 01:01 PM
Mil1ion's Avatar
Mil1ion
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old Apr 15, 2008 | 02:22 PM
Mike's 77's Avatar
Mike's 77
How would I check for a blown power valve on a 2 barrel holley??
leonharu
Oct 1, 2012 08:13 AM
whisler
Oct 26, 2011 12:55 PM
snipa
Nov 2, 2005 05:08 PM
Cap'n Tea Bag
Apr 3, 2005 06:31 PM
fordxxx
Feb 5, 2003 05:59 PM
