Sponsored by: Real Truck
Axle Code from Axle, not Door Sticker Help
Old Mar 14, 2008 | 01:17 PM
Stone Mathews's Avatar
Stone Mathews
Hey all,
I either do not have, or have lost (I just bought this truck used) a door sticker. It's a 1999 F-250 SD SC
The little metal tag on the rear axle reads this:
4101058C20
At lest that is the best I can tell.
Can someone decifer this for me?
Can I assume the 410 means 4.10?
Is this limited slip or not?
THANKS IN ADVANCED!!!
Old Mar 14, 2008 | 01:32 PM
redford's Avatar
redford
FTE Leadership Emeritus
I think this is what you should be looking at:
C2 — 4.10 limited slip, F-250/Excursion
I could be wrong on that, so please wait for other opinions.
Old Mar 14, 2008 | 01:37 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Wouldn't the C2 be the AXLE code listed on the Certification Label?
I'm no braintrust on these newer trucks, but that letter/number combo was what Ford used for many years as an axle code on Certification Labels and Warranty Plates.
ARTICLES/SPECS top of this page has an axle decoder.
What Ford rear axle tags looked like on rear ends from circa 1968 and later was this if LS was present: 4L10. Without LS: 4.10
Old Mar 14, 2008 | 02:18 PM
Stone Mathews
I couldn't remember what the little door sticker was called, it's the Certification Label that I don't have. All I have are the numbers off the metal tag that is attached to one of the bolts on the differential cover.
I've read the ARTICLES/SPECS page, but it only decodes axle codes that came off the Cert Label. Now that redford points it out, I do see a C2 in my number, but that is followed by a 0.
Anyway, thanks a ton for the replies guys. Anyone else wanna weigh in and help me out?
THANKS!!!!!
Old Mar 14, 2008 | 03:25 PM
redford's Avatar
redford
You can always do this if all else fails:
Jack up the back axle, getting both rear wheels off of the ground. Put truck in neutral (remember to block the front wheels and please use jack stands).
First rotate either rear wheel clockwise. Watch what the opposite rear wheel does. If it turns the same direction, you have limited slip. If it turns the opposite direction, you have an open rear diiferential OR a worn out limited slip rear end.
OK, now put a chalk line on the driveshaft, visible from the rear tire where you're at. Rotate the rear tire slowly, counting how many times the driveshaft rotates.
3 3/4 turns means you have a 3.73 differential. 4 turns and a bit more means you have 4.10s. 4 1/4 turns means you have a 4.30.....you get the idea.
Old Mar 14, 2008 | 05:40 PM
PowerStrokeHD's Avatar
PowerStrokeHD
Stone... What is the VIN on the truck?
Old Mar 14, 2008 | 10:02 PM
Stone Mathews
1FTNX21L4XEB69523
Thanks PowerStroke.
Old Mar 14, 2008 | 10:19 PM
PowerStrokeHD
Originally Posted by Stone Mathews
1FTNX21L4XEB69523
Thanks PowerStroke.
The axle code that would be on the VC label is "32" and it is or atleast came from the factory with a 4.10 non-limited slip.
jplinville
Aug 4, 2016 02:23 PM
rlpatte
Mar 27, 2015 10:45 AM
lakerats
Mar 17, 2011 02:40 PM
lakerats
Electrical Systems/Wiring
Dec 8, 2010 08:00 AM
lakerats
18
Oct 16, 2010 09:10 PM
