Biggest tires
Old Mar 16, 2008 | 08:16 AM
uncle.stosh's Avatar
uncle.stosh
Originally Posted by doug1222556
Well I can only go so long without getting silly, .... so here goes- I checked with Bigfoot, and he says you guys aren't even close.
Huh?
Old Mar 16, 2008 | 09:22 AM
Franklin2's Avatar
Franklin2
I think this is who he consulted with.
Old Mar 16, 2008 | 01:14 PM
doug1222556's Avatar
doug1222556
I think Dave gets it.
Old Jul 19, 2008 | 11:42 PM
rmalottwtes30's Avatar
rmalottwtes30
Instead of starting a new thread I searched for the thread I started a while back...But anyways Im back on the kick of new tires, But everyone says I cant run any wider tires...What size tire would you all recommend with stock lift f250 of mine? What size tire and rim should I buy? I dont want something to xtreme just a little wider. Sorry for the dumb sounding questions but Im not tire smart.
Also 235/85/r16 is the metric measurement right?
Old Jul 19, 2008 | 11:55 PM
Sycostang67's Avatar
Sycostang67
I'm not to hip on tire size meanings either. I use online tire size calculators all the time when I am looking at changing sizes. It will give the tire dimensions in inches which is easier for me to understand and compare. Calculate the size you have, then adjust the numbers to calculate the size you want. Here is one for you to try.
Tire Dimensions Made Simple - Discount Tire Co.
Old Jul 20, 2008 | 06:55 PM
rmalottwtes30
The stock rims are 8 on 6.5 correct as in the lug pattern?
The actual rim is 16" tall and 8" wide correct?
Would I be able to fit 17" tall and 8" wide rims on my truck?
If so what size tire would that take?
Old Jul 20, 2008 | 07:05 PM
Sycostang67
Yes
Yes
Yes, I have 17x9 rims on my truck
What size do you want to run? I am running a 285/70R17 which is about 33" tall. It fits just fine with no lift.
Old Jul 20, 2008 | 07:36 PM
rmalottwtes30
Originally Posted by Sycostang67
Yes
Yes
I wouldn't mind running the size your running. Im having troubles finding a good set of rims I like that are a little cheap, not looking for nothing fancy because the truck will be out in the fields...
Old Jul 21, 2008 | 02:41 AM
Sycostang67
I have seen 2 or 3 kinds of 17" wheels for $100 each brand new which is about all I am willing to pay per wheel. The tires will kill you though. My Toyo's, load range "E" cost just under $1000. I was just lucky my wheels were free since my sister gave them to me. Keep your eyes on craigslist too, some pretty cool stuff shows up once in awhile.
Old Jul 21, 2008 | 09:18 AM
Franklin2's Avatar
Franklin2
Just a reminder for him(rmalottwtes30) to be careful with the load range of the tire. I am not too familiar with the 17" tires, but do know the 16" sizes come in styles with lots of plys to handle the weight rating of your truck. He has a f250, so he needs tires rated for a f250 if he is going to use it as a truck.
Old Jul 21, 2008 | 06:34 PM
uncle.stosh
No. Stock size rims are 16 X 6 (truck) or 16 X 7 (van), they are not 8" wide.
As I have already stated, a 265/70 R16 is about the limit for a 6" wheel, and you can fit 285/70 R16's on a 7" wheel.
That's what I'm running right now but they do rub the springs a little bit at full lock.
That's ok, don't bother to read what I've already posted. What the hell do I know.
Old Jul 21, 2008 | 08:00 PM
80F100man's Avatar
80F100man
I had 33x12.5-15s on my '83 F-150 4x4 w/o lift on 10" wide wheels......no rubbing either
Old Jul 21, 2008 | 08:18 PM
  #28
Franklin2's Avatar
Franklin2
Non-stock wheels there. They usually will not rub.
Old Jul 22, 2008 | 09:49 PM
  #29
lift_it_higher's Avatar
lift_it_higher
im runnnig 35x12.50 bfg mud terrains on 15x8 eagle alloys and i think they are on of the better on off road tires out there not bad on the road and still have plenty of grip for the trials
Old Jul 23, 2008 | 06:16 PM
  #30
Dave Sponaugle's Avatar
Dave Sponaugle
235/85-16 tires work out like this.
25.4 mm to 1"
235 / 25.4 = 9.251" wide
9.251 * .85 = 7.863" tall sidewall
The 16" is wheel bead to bead height.
So two sidewalls + one wheel height = diameter.
7.863 + 7.863 + 16 = 31.726" tall tire
Something else to watch on aftermarket wheels on trucks is the strength of the wheel.
I have looked at several aftermarket wheels for 8 lug trucks that have load ratings under 2000 pounds each.
So 4 of them would hold my empty truck.
fxstbchopper
Nov 24, 2008 11:47 AM
mattpowerstroker
15
Feb 3, 2008 09:24 PM
polcat
Offroad & 4x4
13
Jan 15, 2007 06:37 PM
j tate
Dec 16, 2006 05:22 PM
Fat Ford Boy
1997 - 2003 F150
20
Jan 16, 2004 07:01 PM
