Biggest tires
Old Mar 13, 2008 | 09:27 PM
rmalottwtes30's Avatar
rmalottwtes30
Biggest tires
What is the widest, and tallest tire I can run, right now my tires are 235/85/r16. I am keeping the same rims and was wondering if I could run a wider tire. Thanks
Old Mar 14, 2008 | 03:55 PM
MagPede's Avatar
MagPede
I assume you mean for your f250. I have 285/75-16 nitto terra grapplers on my my 86 f250. They've been fine but ya better stay away from mud.
Old Mar 14, 2008 | 08:29 PM
ol' gray's Avatar
ol' gray
how do those terra grapplers handle the mud and snow? they look pretty good to me but ive never driven a pair of them? i have goodyear wrangler at/s on right now and im not very happy with them so im lookin for some new ones
Old Mar 14, 2008 | 08:51 PM
MagPede's Avatar
MagPede
Well they're definately not for mud bogging but moderate stuff they'll do fine or if you have a lil speed (trac-lock helps too). I can't say about snow as we haven't had any here in a few years and it's never more than a couple inches. They drive fine, no road noise or anything like that. Although after I bought mine, I found out that they have a load range D and E in the particular size I have. I got the D load range which probably rides better.
Old Mar 14, 2008 | 08:53 PM
ol' gray's Avatar
ol' gray
ok thanks! sorry i diddnt mean to change the subject
Old Mar 15, 2008 | 09:41 AM
beaners1's Avatar
beaners1
32x12.5 were as big as I got on my F150, they rubbed in a tight turn, not exactly sure on the 250.
Old Mar 15, 2008 | 09:58 AM
uncle.stosh's Avatar
uncle.stosh
If you are talking about keeping your stock 16X6 rims, they will be the limit on how wide of a tire you can SAFELY run.......
Some times you can find 16X7's in the junk yard, and you can obviously run a slightly wider tire.
If you are talking aftermarket, that's a whole other story and depends on the width.
Old Mar 15, 2008 | 09:59 AM
Franklin2's Avatar
Franklin2
If you keep the same rims, then you can't go very wide. I had a f150, so it's a little different than your larger truck, but with the stock rims on it, I ran 31x10.5 tires, and they fit ok, but in a tight turn in the parking lot, they rubbed the radius arms(you do not have radius arms but you do have leaf springs in the same spot.
I ran the same exact tire on a aftermarket 8 inch wide chrome rim, and they did not rub in a tight turn. The aftermarket rims set the tires farther out, which gives you more clearance.
A guy I know at work has a 89 f250 diesel, and he's running 33x12.5 tires on his truck with no lift. But, he has aftermarket 10" aluminum rims, so that makes a lot of difference on his too.
Old Mar 15, 2008 | 10:13 AM
rmalottwtes30
Anyone know what my tire actually measure by looking at the 236/85/r16? or do I need to actually go out and measure?
Yes there the stock rims. So im guessing the stock size tire is about all I can run? Im not looking at taller tires now I guess maybe just a little wider.
Old Mar 15, 2008 | 11:36 AM
uncle.stosh
You can safely run LT265/75 R16's. That's what I have on my truck.
I don't think you can put anything wider on them than that.
Best bet is to go to a tire website and look up the size you are thinking about. They have recommended rim widths listed for their tires.
Old Mar 15, 2008 | 12:50 PM
doug1222556's Avatar
doug1222556
[QUOTE=Franklin2]
Rims come in different offsets, and if you get the wrong offset, they will actually make the problem worse.
Old Mar 15, 2008 | 12:52 PM
big hoss 29's Avatar
big hoss 29
LT235-your sidewall is 235mm tall
85-the tread width is 85% as wide as the sidewall is tall
16-you have a 16" rim
LT235/85/16
If I remember right, a 235/85/16 is just about the same height as a 31x10.50 tire.
Old Mar 15, 2008 | 06:26 PM
IcemanV8's Avatar
IcemanV8
Correct me if I'm wrong, but do you not have that backwards?
Example: 245/55 16's.
245 = 245mm wide
55 = sidewall is 55% of 245mm
16 = duh. wheel size.
Old Mar 15, 2008 | 09:03 PM
Franklin2's Avatar
Franklin2
Yes, he did have it backwards. The 235mm is the tread width.
Old Mar 15, 2008 | 09:34 PM
doug1222556
Well I can only go so long without getting silly, .... so here goes- I checked with Bigfoot, and he says you guys aren't even close.
