front end "thunk, thunk"
Old Mar 12, 2008 | 04:06 PM
judi48's Avatar
judi48
Hey all,
My 66 has a "thunk, thunk" noise when I take off from a stop. I've replaced the king pins and wheel bearings. Shock mounts and coil spring perches look good.
What's next??
Thanks,
Judi
Old Mar 12, 2008 | 04:15 PM
Mike G's Avatar
Mike G
Drive shaft carrier bearing? Tie-rod ends? Radius arm bushings?
--Mike
Old Mar 12, 2008 | 05:28 PM
camperspecial65's Avatar
camperspecial65
sounds like radius arm bushings...they are the big arms going rearward from the front spring area and attach in the area about under your feet when in the truck.
- cs65
Old Mar 12, 2008 | 05:30 PM
camperspecial65
btw, bushings should be around 3/4 inch thick or so...but as bad as your noise sounds, if it is a bushing, it sounds as if one or two would be all but gone. If so, they are easily obtained and are cheap
- cs65
Old Mar 12, 2008 | 06:15 PM
judi48's Avatar
judi48
LOL, you guys ALWAYS come up with the best info. The tire rod ends are in good shape so I'll chase the bushings.
Thanks!
Judi
Old Mar 12, 2008 | 06:16 PM
judi48's Avatar
judi48
PS- Mike,
I've got a specially made drive shaft- it has a slip joint but no carrier bearing...
Old Mar 12, 2008 | 07:00 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Thanks!
Judi
I'm bettin' on the radius rod bushings, too.
There are two sizes on each arm, plus a large washer.
Ford (updated) part numbers:
2) D5TZ-3B203-D .. Rear (replaces C5TZ-3B203-B)
2) D5TZ-3B203-E .. Front (replaces C5TZ-3B203-C)
Before spending the green, try tightning up the nut on each arm. Some past owner may have not snugged the nut down and it has worked loose...that's rather common.
Old Mar 13, 2008 | 06:48 AM
matt2491's Avatar
matt2491
I used to hear a pretty audible "thunk" coming from the truck when I took it around turns.
It turned out being the leaf spring bushings, which were COMPLETELY shot. Once I replaced them, the truck felt smoother and tighter. It helped it track down the road straighter as well.
Old Mar 13, 2008 | 11:51 AM
judi48's Avatar
judi48
ND- the back bushing is pretty obvious, but where is that front one located? Is it the bolt that goes up through my coil spring? (LOL, Guess that question explains to Matt that I don't have front leaf springs... )
Old Mar 14, 2008 | 07:14 AM
NumberDummy
ND- the back bushing is pretty obvious, but where is that front one located? ON THE OTHER SIDE OF THE SUPPORT BRACKET THAT HOLDS THE RADIUS ARM TO THE FRAMEIs it the bolt that goes up through my coil spring? (LOL, Guess that question explains to Matt that I don't have front leaf springs... )
Sequence of assembly.
> > Nut threads to end of radius arm - small washer - front bushing - support bracket to frame - rear bushing - large washer.
Erik Jaeke
25
Sep 22, 2015 04:13 PM
autumnwyatt12
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Sep 4, 2014 08:42 PM
jkidd_39
16
May 27, 2010 01:39 PM
FordSDF250
Feb 8, 2008 03:09 PM
Craig64
Jan 30, 2007 02:08 PM
