patch panel has rust?
Old Mar 11, 2008 | 08:14 PM
rtcalabrojr's Avatar
rtcalabrojr
Darksider
What to do with a patch panel that has surface rust? I have used a disc sander on it but there is still some left behind, very light pit marks. I would like to use the patch because the fit is great. Dont know where it came from it was in a truck that i bought. So i do i get it out other than sand blasting? Then panel is a pass rear cab corner. Thanks RT
Old Mar 11, 2008 | 08:19 PM
ford_boy_1996's Avatar
ford_boy_1996
Maybe a wire wheel but....Sand blasting would be the best way I know of though.
Old Mar 11, 2008 | 08:30 PM
rtcalabrojr
Darksider
i did not know if the sand blasting would warp the panel?
Old Mar 11, 2008 | 08:36 PM
ford_boy_1996
I think it would have to be realy thin, or you would be using a bad azz sand blaster before it would warp. I would just sand blast it and take it easy on it.
Old Mar 11, 2008 | 08:39 PM
bobj49f2's Avatar
bobj49f2
Either use a light duty sandblaster or a rust stripper like phospheric acid if it light pitting.
Old Mar 12, 2008 | 08:42 AM
Steve_B's Avatar
Steve_B
For light rust I use POR-15 Metal Ready
Old Mar 12, 2008 | 08:55 AM
irondragon79's Avatar
irondragon79
I'll echo the phospheric acid type wash (which is what POR-15 metal ready is).. I think another name brand I have heard of is Naval Jelly.
Old Mar 12, 2008 | 02:27 PM
cts1954's Avatar
cts1954
I was watching Power Block TV the other day and I think it was on Muscle Car, they used a bath solution of distilled water and baking soda and connected the part to a battery charger. It cleaned the part down to bare metal, looked interesting. Try looking on their web site.
Good luck
wgc
Old Mar 12, 2008 | 03:00 PM
cmoritz's Avatar
cmoritz
Phosphoric acid (phospheric?) , Por 15 metal ready, ..
What paint prep for 2 stage b/c coat? water rinse?
I've been reading stuff about this procedure for rust removal...
What prep is required before application of an etching primer??
Home Depot/Lowes is supposed to be carrying Ospho..same sort of stuff...Don't mean to be hijacking this thread RT , but I think it kinda answers your question,and set's up the next..
Old Mar 12, 2008 | 03:21 PM
rtcalabrojr
Darksider
at work theres a glass bead blaster that i can try, i was told to try that.
Old Mar 12, 2008 | 04:03 PM
bobj49f2's Avatar
bobj49f2
If you have bead blaster available go with that, end of problem.
With phospheric acid you have to rinse with water and blow of with a dry, compressed air, coat ASAP.
Old Mar 12, 2008 | 09:42 PM
rcav8or's Avatar
rcav8or
If you use it, SUPPORT IT
Good luck
wgc
actually, that was "Washing Soda" probably, a little different than baking soda, but comes in the same looking box.
It's usually in the laundry section. Here's several links on the subject, the last one is best:
Link One
Link Two
Probably the best one, with pictures: Link Three
It's a great way to remove rust, doesn't take ANY metal away, will not take of good chrome (will take it off, if rusted underneath), nor most paints.
R
Old Mar 13, 2008 | 04:45 PM
rtcalabrojr
Darksider
I tried the blaster at work and it did not work so good. Its now in the washing soap and 2 amp battery charger tank having a bubby bath as we speak!!!
Old Mar 13, 2008 | 11:08 PM
brucewolff's Avatar
brucewolff
I would recommend sandblasting for rust pits....you won't warp it if you work at it from a steep angle and for short periods at a time.
Old Mar 14, 2008 | 05:33 AM
rtcalabrojr
Darksider
The bubbles are going strong as we speak, its been in there since 6:00 pm yesterday and the rust has turned black and falling off. I also hit it with a wire brush some. I took some pics and will post them soon.
