patch panel has rust?
Old Mar 14, 2008 | 09:00 AM
rcav8or's Avatar
rcav8or
If you use it, SUPPORT IT
Originally Posted by rtcalabrojr
The bubbles are going strong as we speak, its been in there since 6:00 pm yesterday and the rust has turned black and falling off. I also hit it with a wire brush some. I took some pics and will post them soon.
Wow, sounds like it's working great! Yes, pictures...we LIKE pictures!! I have everything, and will be doing it soon, but just haven't - too many other projects. But soon, VERY soon! (story of my life!!).
R
Old Mar 14, 2008 | 09:29 AM
AXracer's Avatar
AXracer
I hope you used washing SODA (should say sodium carbonate as the only ingredient on contents lable) not washing SOAP. Rinse with HOT water and dry completely immediately after removing from bath using rubber gloves to prevent skin acid contact then give a coat of primer or a wiping with a light motor oil or it will start rusting again overnight just from the moisture in the air. I like using a 3M clean and strip wheel (looks like grey plastic "steel wool") with a wipe down with rust converter after to treat light surface rust.
Old Mar 14, 2008 | 09:53 AM
homade's Avatar
homade
Who says there is nothing on TV anymore, i just wish they had a FTE program, now would that be INTERESTING OR WHAT, i say that program on TV but it was after i had blasted wire brushes sanded and and and i forgot all the other things i tried.
Old Mar 14, 2008 | 06:42 PM
WALFORD'S 56's Avatar
WALFORD'S 56
Run a d.a. sander over it,primer it and mask the edges so you can weld it on to your truck. I would not worry so much about the patch till you have it on the truck.....Bill
jvmcc
Jun 9, 2011 04:28 PM
DaytonaTunnel
Feb 11, 2009 09:51 PM
boggerted
Paint & Bodywork
Oct 31, 2008 06:54 PM
jvmcc
Jun 25, 2004 08:38 AM
HJackson
Nov 7, 2003 08:18 AM
