Runs hot + temp varies
Old Mar 11, 2008 | 09:45 AM
86stepsideF150's Avatar
86stepsideF150
I had a leaking waterpump on my '86 F150/301 EFI. I installed a new waterpump, and went ahead and installed a new thermostat as well. It doesn't leak now, but the temp. varies when it's driven. When it first heats up, sometimes the temp. will reach the "L" in "NORMAL" on the water temp. gauge, and it will like a few minutes of driving for the temp. to settle back to exactly halfway on the gauge. It doesn't ever "overheat", and the gauge never bottoms out, but sometimes it gets a little hot. Is this something to be concerned about? I'm pretty sure I didn't put the thermostat in backwords, so what else could cause this, if it is a problem?
Old Mar 11, 2008 | 11:36 AM
klxstiffler's Avatar
klxstiffler
you could have air pockets in the cooling system. recheck the coolant level after it's completly cooled down.
Old Mar 11, 2008 | 12:34 PM
chrisf250-460's Avatar
chrisf250-460
sounds like air trapped in your cooling system
Old Mar 11, 2008 | 01:36 PM
65f100_352's Avatar
65f100_352
Just throwing this out there, but it could be your gauge or temp sender. Just a thought.
Old Mar 11, 2008 | 08:31 PM
cleeE150's Avatar
cleeE150
go with after market gauge, so you know true temps, right now your guessing..
fordsuperduty250
Jul 14, 2012 10:05 PM
cmysho
43
Jan 22, 2011 12:54 AM
CF-DRG
Apr 22, 2006 09:36 PM
monte54
15
Feb 13, 2004 11:55 AM
fordwel
Mar 3, 2001 08:51 PM
