I have a 1977 F250 with a 460 engine in it. It runs great, and has a new thermostat, clutch fan and waterpump. The temp gauge has a new sending unit, but the temp on the gauge goes full hot after as little as a mile. I put a thermometer on the thermostat area after I ran it awhile and the temperature never got over 160. Does anybody know if it's just the gauge, or some other gremlins?
I have the same setup, ' 77 with a 460 and the temp always reads high also but never out of the "normal" range. I came to the conclusion that it must be the calibration of the temp gauge since the engine runs fine and there are no signs of overheating ie hot rubber, slowing down, boiling over etc. If you get a little figgity about the temp just make sure you check the radiator often and keep the oil up and fan clear. Sometimes it helps to run the heater to blow some of the heat away. My temp gauge goes up and down with the rpm of the motor. When I'm at a light the gauge reads hot but as soon as I'm moving it cools down again. (sorta runs in sync with the oil pressure) Hope this is a little re-assuring for you.
You might want to pick up an after market gauge from your local parts store.They are simple to install and if you use a t-fitting you can keep you original gauge hooked up as well.This is cheap insurance to prevent you from frying your engine.
Many thanks to all who replied. I bought the parts because my work sometimes takes me to remote areas, and the truck has to be absolutely dependable. The pump bearing was loose, and the fan clutch was weak, so both were replaced. This is the first Ford truck I've owned, so I'm not familiar with any quirk they would have. I had a 68 Lincoln about 13 years ago, but it is different then a truck. again, many thanks to all.
ive owned every type ford there is [trucks] if you dont have a fan shroud try that some of them need it also make sure your clucth on your fan works properly
Rebuilt my 77 460 and have the same thing happening,I have put 9000 miles on the re-built engine,just keep an eye on oil and coolant level,the panel cluster regulator may cure the problem.
Also,make sure the cluth fan is operating properly.I believe you'll be ok.
