Clutch issues!!
Old 03-09-2008, 10:01 PM
mklemin's Avatar
mklemin
mklemin is offline
Clutch issues!!
Hey guys i have been haveing some issues with my clutch, i guess it is the stocker not for certain though. what is happening is i have to mash the clutch peddle to the floor for it to fully disengage and still it is hard to get into gear and sometimes grinds while going into gear. Also when i start up my truck you can tell it isnt totally disengaged cause it wants to move forward.. what would cause this and how do i fix it. thanks all
Old 03-09-2008, 10:15 PM
NWO_diesel_nut's Avatar
NWO_diesel_nut
NWO_diesel_nut is offline
Wink
Take a look underneath the dash. With the truck off, press the clutch down and look at the linkage between the master clutch cylinder rod and the lever that pushes it down. Between the lever and the eye of the cylinder rod there is a metal post welded to the lever and a small plastic bushing that slips over the post and goes through the eye of the rod. It is probably worn, so take a look at it and get back to us.
You can simply pull the clutch rod off to the side of the post/lever to get a better look at it.
Old 03-11-2008, 10:34 PM
mklemin's Avatar
mklemin
mklemin is offline
i have actually replaced that whole metal peice clutch master cylinder and the all important plastic sleeve. really cant figure it out is there any way of adjusting it or no? thanks
Old 03-11-2008, 11:12 PM
powerstrokeddiesel's Avatar
powerstrokeddiesel
powerstrokeddiesel is offline
no... you can not adjust these clutches...
Old 03-11-2008, 11:20 PM
NWO_diesel_nut
Take the master cylinder rod off of the lever post and see if the rod will retreat further from the firewall. What I mean, is that if it goes past the point of the post towards the steering column, than you will have to adjust the position of the lever.
Old 03-12-2008, 10:49 AM
MagKarl's Avatar
MagKarl
MagKarl is offline
When you say metal piece, are you talking about the part that has the pin that the plastic bushing installs onto? That part is held onto the pedal assembly with a nut, but it's a splined fit. Maybe you can clock that part by one tooth and get more travel?
Old 03-12-2008, 11:13 PM
mklemin's Avatar
mklemin
mklemin is offline
Yeah that is what i was wondering if i would have to move that peice just a little to adjust but would moving it that little would it make that big of a difference?
Old 03-13-2008, 12:15 AM
scatgo's Avatar
scatgo
scatgo is offline
Dont forget ther are bushings around the shaft that goes from the clutch pedal to the right side. Mine are so shot the pedal will move down about a inch just to take up that slack.
Trapperpete52
10-22-2016 06:12 PM
zack987
16
04-14-2015 02:06 PM
hayden01
18
08-06-2014 09:01 PM
Visseroth
04-28-2013 07:29 PM
Pharwell04
11-04-2004 03:33 PM
Quick Reply: Clutch issues!!
