Help!
Old Mar 10, 2008 | 03:13 PM
2kcrewcab's Avatar
2kcrewcab
waterpump would cause you to run hotter. Your symptoms are of a stuck open t-stat.
Old Mar 10, 2008 | 07:11 PM
MSB6's Avatar
MSB6
I might have it fixed. I did the flush and fill again today with the previously new installed cap, and t-stat. I kept filling and opening the cap, burping the hose,go and drive it, add a little more fluid. It kept taking more fluid and I got 140 degree air out of the vent a couple of times. Top rad hose is nice and hot, both heater hoses heating up good. I dont know, it seem good, but I thought I had it fixed once or twice before. And all of a sudden little or no heat. Maybe the fluid level wasnt up high enough and it had air in it. I would still like to know what temp others are getting out of their vents on high heat. Just curious
Old Mar 10, 2008 | 07:56 PM
sbclemens's Avatar
sbclemens
Make sure you check the coolant level every couple of days for the next few weeks. It takes time to bleed all the air out of the system.
Fomoco1546
Modular V8 (4.6L, 5.4L)
May 1, 2014 10:38 PM
thinksnow
May 21, 2013 03:28 PM
greentree ford
Nov 15, 2012 04:24 PM
tom302
Sep 10, 2010 08:49 AM
ilo9
Jun 8, 2009 06:57 PM
