Sponsored by: Real Truck
gear ratios
Old Mar 9, 2008 | 11:06 AM
yamaracer18's Avatar
yamaracer18
gear ratios
whats better the 3.73 or the 3.55? tuck will be mostly a daily driver with towing in the winter time for snowmoibling!
Old Mar 9, 2008 | 12:03 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Moved...enjoy~
Old Mar 9, 2008 | 01:46 PM
GregsSD's Avatar
GregsSD
Need to know what truck you have,gas or diesel, 4x2 or 4x4, stock or lifted, what size tires you have.
It all makes a difference!
Old Mar 9, 2008 | 03:34 PM
biz4two's Avatar
biz4two
Arrow
What he said.
Got to give us more...sounds like you might be looking at a '08 SuperDuty with the new option of 3.55 gears and PSD 6.4L...right?
biz
Old Mar 9, 2008 | 05:00 PM
yamaracer18
yea thats what i am looking at probally a ext cab 6.4 4x4 lift at some point in time maybe, mostly a daily driver and will be towing a enclosed sled tailer with 4 sleds in the winter
Old Mar 9, 2008 | 10:10 PM
biz4two's Avatar
biz4two
Arrow
Well based on that info...IMO...go with the 3.73 gears. The towing...and mainly the lift (larger tires) are the reason here. However, if you were going to keep the SD all OEM stock...then the 3.55 would be the way to go.
biz
Old Mar 10, 2008 | 09:32 AM
bpounds's Avatar
bpounds
For Job 3 '08s with the 6.4L the 3:55 gears are now standard. They are trying to help us with the fuel mileage which has been a major complaint with the new motor.
They did not lower the tow ratings. So apparently Ford thinks the motor still has plenty of torque up to it's rated tow capacity. Considering the 6.0 had 70 ft/lbs less torque and was/is a very capable tow vehicle, I would say they are right.
So, unless I was towing a large trailer at near the maximum weight rating, I think I would go with the 3:55's. What you propose to tow is childs play for that truck, so stick with the 3:55's and enjoy a little better fuel economy. You will have plenty of power.
Bill
frank5079
New Member Introductions
Jul 21, 2016 12:21 PM
Vinford
Nov 2, 2015 04:42 PM
jdigio1960
Mar 2, 2011 09:41 PM
gus11208
52
Nov 21, 2010 02:42 AM
tippmann87
Feb 25, 2008 03:38 PM
