New BAD starter???
Old Nov 20, 2001 | 09:22 PM
Stuckinmud's Avatar
Stuckinmud
New BAD starter???
Ok after a few more hours out in the cold and darkness ive decided to pull out my recently puchased starter. This is the same starter i took down to the parts store and had tested, they said it was working fine. I decided to test it myself. I hooked up a ground and gave it some power...the bendex gear popped out but it wasnt spinning!!!! Profanity Removed?? Is it possible i got a bad starter?? It started the truck a few times now its shot??? What do you guys think???
Old Nov 20, 2001 | 09:55 PM
Bill_Beyer's Avatar
Bill_Beyer
New BAD starter???
I wouldn't be the least bit surprised if you got a bad rebuilt starter. If you'd ever seen the rebuild process you'd feel the same way. I suggest you take it back and get a new one.
Old Nov 22, 2001 | 10:31 AM
telesqrt's Avatar
telesqrt
New BAD starter???
I've had bad luck with the rebuilt starters also. I've gone with re-manufacture ones with good results, they pretty much only reuse the casing. Everything else is new, unlike rebuilt ones were if it looks ok its left in the starter. Going with a new one is always good but like with everthing else in life there's guarantee.
1979 F-350 supercab 4x4, 400, NP435, rebuilding.1 owner.
Old Nov 22, 2001 | 12:27 PM
Franklin2's Avatar
Franklin2
New BAD starter???
Spktyr
55
Dec 28, 2016 08:56 AM
Talyn
13
Dec 16, 2012 10:05 PM
cdorroh
16
Sep 9, 2007 03:19 PM
patmorrison
13
Feb 27, 2004 03:20 PM
jamlove
Jan 26, 2004 12:17 PM
