First attempt at data logging with AE
Old Mar 8, 2008 | 03:19 PM
white Buffalo's Avatar
white Buffalo
Here is my first attempt at datalogging with AE showing the ICP and duty cycle, I was glad to see my stock HPOP was able to get over 3K and hold without dropping. I probably should have graphed each chip setting individually and added mph but I'm still learning how to do this stuff with the help of Tenn01psd350 (Mike) and others.....<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
did I do this graph correct???......
Stock HPOP looks strong, but I'm not sure if I am setting up the graph correctly?
but everytime Mike helps me I drink beer and can't remember
<o></o>
Old Mar 8, 2008 | 04:09 PM
PaysonPSD's Avatar
PaysonPSD
That HPOP does look strong. How many miles? AE is on my wish list and that will be my first data logging event.
What are the 4 different settings?
Old Mar 8, 2008 | 04:13 PM
white Buffalo
truck has 100,300 miles on it. If your passing through the area, give me a shout and you can use mine.....
Old Mar 8, 2008 | 04:21 PM
PaysonPSD's Avatar
PaysonPSD
I have 95k on mine and your results are encouraging. Mine will be less just due to to the fact it has a 15° swash plate but maybe I will see in the neighborhood of 2500. Could happen.
If I ever pass through Ft. Sill I will give you a shout whether I have AE or not.
Old Mar 8, 2008 | 07:43 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Looks good Rich. PM sent. Maybe the reason we have these technical hiccups is because of the beer. At least we should be on the same sheet of music.
Old Mar 8, 2008 | 08:18 PM
white Buffalo
Were on the same sheet of music when we have the beer, it's afterwards that my sheet disappears!
Old Mar 12, 2008 | 11:31 AM
white Buffalo
OK Mike, I did as you suggested.
I data logged a single program (tow program). Started at 70 and punched it.... after 10 secs crossed over 100 and she kept pullin harder.....Geez, I hope this post does not get my a$$ a ticket....
Old Mar 12, 2008 | 12:27 PM
Tenn01PSD350
Rich, it looks like your single shots are getting all the oil they need. That is awesome.
bismic
Mar 9, 2022 09:20 AM
Truckandute
Aug 28, 2014 01:42 PM
K8's Ford
13
Oct 19, 2010 05:39 PM
Bdox
18
Jan 20, 2008 10:29 AM
gehrig
13
Aug 1, 2005 08:28 PM
