Here is my first attempt at datalogging with AE showing the ICP and duty cycle, I was glad to see my stock HPOP was able to get over 3K and hold without dropping. I probably should have graphed each chip setting individually and added mph but I'm still learning how to do this stuff with the help of Tenn01psd350 (Mike) and others.....<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
did I do this graph correct???......
Stock HPOP looks strong, but I'm not sure if I am setting up the graph correctly?
but everytime Mike helps me I drink beer and can't remember
truck has 100,300 miles on it. If your passing through the area, give me a shout and you can use mine.....
I have 95k on mine and your results are encouraging. Mine will be less just due to to the fact it has a 15° swash plate but maybe I will see in the neighborhood of 2500. Could happen.
If I ever pass through Ft. Sill I will give you a shout whether I have AE or not.
I data logged a single program (tow program). Started at 70 and punched it.... after 10 secs crossed over 100 and she kept pullin harder.....Geez, I hope this post does not get my a$$ a ticket....
