Sponsored by: Real Truck
brake controler wiring
Old Mar 8, 2008 | 11:17 AM
woody367's Avatar
woody367
I just got the Prodigy brake controler and Ford harness for my 04 F2250. The truck has the trailer tow package. Where should the truck conector be? Do I just plug and go or do I need to put a fuse or relay in some where to activate the system like I had to on my GMC?
Old Mar 8, 2008 | 12:42 PM
rbaker6336's Avatar
rbaker6336
I am assuming the controller plugs in like a 2000
if you remove bottom panel to fuse box,the plugin should be to the right of steering column kinda above throttle pedal on adash support
Old Mar 8, 2008 | 12:54 PM
woody367's Avatar
woody367
Thanks I will check. Did you need to add ant fuses or relays or just plug in and go?
Old Mar 8, 2008 | 12:56 PM
rbaker6336's Avatar
rbaker6336
you will probly have to add some fuses and relays to the undehood fuse box
check you owner manual it should show them
Old Mar 8, 2008 | 01:24 PM
dkf's Avatar
dkf
Plug a go for me.
I have the P3 on my 04' SD and my dad has the Prodigy on his 03' SD. We both got the premade harness Tekonsha sells with plugs on both ends. We Mounted the controllers plugged the Tekonsha harness into the grey plug behind the dash and we were set.
The Tekonsha wiring harnes costs $10. http://www.tekonsha.com/bch3035.html
Old Mar 8, 2008 | 03:18 PM
woody367's Avatar
woody367
I did get the harmess that they sell for my truck. I will check the book if it needs the fudes. Thanks
Old Mar 8, 2008 | 09:52 PM
cschannuth's Avatar
cschannuth
No fuses needed. Just find the plug, plug it in, and you're all set.
Old Mar 9, 2008 | 07:54 AM
rmosso1's Avatar
rmosso1
I had the prodigy brake controller on my 2003 Excursion. Just plug and play. I remember well bacause I watched the guy do it. I asked a simple question to the trailer manufacturer/dealer in Florida. "You mean I am paying $250.00 installation for that"? ANSWER: YEP!~
sailorman3
Apr 17, 2013 10:49 AM
cdrmotorsports
All Things Towing
Mar 12, 2008 05:46 PM
slimfitz
All Things Towing
Aug 20, 2007 06:03 PM
ucop27
Dec 1, 2006 10:27 PM
Jetsfan68
Electrical Systems/Wiring
May 3, 2002 02:37 PM
