fixin this stupid leak once and for all!!!
Originally Posted by 2 stroke man
its coming from right around the housing. i cant pin-point it. theres some in front of housing, and some behind it. cant figure it out exactly. but, i do know its coming from somewhere on the housing
click to enlarge.
and the older canisters (before ´96) looks like this:
you also can use this for detect the leak:
http://spectroline.com/hvacr/hvac_dyes_gasglo32.html
I hope this helps you.
Originally Posted by RÖENTGEEP
I bet the canister is leaking thru a weephole (mine did), here are some picts of the canister and you can see where is in front and behind the housing.
click to enlarge.
click to enlarge.
Originally Posted by kawa
Get some of that "Off Road Diesel" its got that purdy dye to help ya find it or.........cat urine and a woodsman lamp and it'll glow. LOL
Note: The above are NOT viable suggestions
Rog
Rog
Just take off your fuel filter cover, take a couple cans of carb clean, get your valley cleaned out as best you can, then blow it out with some air. Once it's all clean start your truck, get up over the engine and as you will notice there are a few different sumps in your valley, there are 2 right around the fuel pump area, if the pump is leaking out the weep hole it will begin to fill up the sump 2nd from the back of the engine, there are also 3 lines from the fuel pump to the filter to watch to. Also keep an eye on your filter housing, there is the sensor on top and also the water/fuel sensor on bottom, they are both leakers. Most of the the time since the fuel change to low sulfer we've been changing fuel pumps more often then the sensors (never the cheap fix). The weep hole I'm talking about is actually on the fuel pump itself, once you pull it out of there you will see it. This can be done easily enough without removing the turbo to, the only tricky parts is getting that banjo fitting started agian.
