Stupid fuel filter!
Old Nov 14, 2013 | 04:26 PM
dylansf23's Avatar
dylansf23
Stupid fuel filter!
I can't get this damn thing off.
It wouldn't budge by hand. I then tried a oil filter wrench but it was too big and wouldn't grab it enough.
I then tried multiple belts, all resulted in then stretching or snapping.
I then figured well imma pry against the mount, and got a good two full turns and now it won't even budge, either way.
Been using kroil since the beginning.
Also stuck a screw driver through the side and that helped with the two full turns but now it doesn't.
Right now I'm taking a break but when I go back put I'm going to take the mount off and take it into work and get this damned thing in a vice and get the filter off
Old Nov 14, 2013 | 05:30 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Lightbulb lefty loosey
describe the direction you turned the filter.example; screw driver pushed through filter from engine side towards passenger fender,i then turned handle from firewall to grill.
Old Nov 14, 2013 | 07:05 PM
dylansf23's Avatar
dylansf23
I took the mount off, put it in a vice.
Then tried everything. Finally a giant pair of pliers got it done.
Now my fuel filter didn't fit.
I thought I saw someplace that the 3617 and 3417 would fit the 6.9. I want a drain plug on mine since my engine has been sitting for a few years
Old Nov 15, 2013 | 06:58 AM
tjc transport's Avatar
tjc transport
i ain't rite
it probably don't fit on there now because whoever put the last one on either put the wrong filter on or cross threaded the filter on and buggered up the threads in the mount.
it sounds like it is new mount time.
Old Nov 15, 2013 | 10:29 AM
dylansf23's Avatar
dylansf23
Will the 7.3 mount just go on or will I need to change the fuel line adapters?
Old Nov 15, 2013 | 10:42 AM
dylansf23's Avatar
dylansf23
What's it called?
Old Nov 15, 2013 | 11:28 AM
dylansf23's Avatar
dylansf23
I found it!
I pocket opened a parts PDF and it was on the page! It's a fuel filter header.
Old Nov 16, 2013 | 07:18 PM
sak778's Avatar
sak778
The 7.3 mount is further away from the fuel pump (sits up higher to fit the longer filter) so you would also need the longer hard line from the mechanical pump to the filter header. then the longer line from it to the Injection pump as well. If you could get all these parts from a 7.3 donor in a "pull it" yard you should be good to go! Along with the bracket it mounts to as well, or just fab up a couple of extensions to raise it up from the 6.9 mounting holes. if I remember the difference is only like an inch or so. I'm still wanting to do this on mine and still collecting all of the above mentioned pieces...
YMMV Sean
Old Nov 16, 2013 | 08:44 PM
dylansf23's Avatar
dylansf23
Thanks for the info, there are no junk yards around here and the ones that are close by (an hour and a half) don't have any idi, or heavy duty trucks for that matter.
Old Nov 16, 2013 | 09:26 PM
sak778's Avatar
sak778
LKQ Self Service - Savannah | LKQ Pick Your Part
Cash-n-Carry | Grainger Family Owned Salvage Yard
Sometimes you just got to go and have a look and see what you can find.
Pull-A-Part Locations - Pull-A-Part
I've driven to Atlanta, Charlotte, and Columbia to check out a new "pull-a-part" yard. Their open 7 days a week....
Old Nov 16, 2013 | 11:57 PM
ifrythings's Avatar
ifrythings
YMMV Sean
Hmm..... that's odd, my 87 with a 6.9 had the 6.9 fuel filter head on it and I just put a 7.3 one on and didn't change any lines. I'm not sure if the earlier 6.9's were different or not
Old Nov 17, 2013 | 01:05 AM
dylansf23's Avatar
dylansf23
I called them, and I don't have the time to go driving around, in December I will, but not right now, and I need this up and running as fast as possible, so mods like that that are not necessary will be post postoned
mrjc
6.7L Power Stroke Diesel
31
May 15, 2021 03:16 PM
joejackF250
Aug 10, 2013 12:32 PM
mozzles
19
Oct 17, 2012 11:30 PM
2001gocougs
Nov 30, 2006 10:57 PM
sikboater
Feb 22, 2005 02:24 PM
