Where is this PCM?
Old Mar 7, 2008 | 03:57 PM
fordmancounty's Avatar
fordmancounty
Question Where is this PCM?
Where would you find the powertrain control module at? could somebody show a pic of it and where it would be located at? is there a test that i can do to see if it is in working order? thank you in advance.
Old Mar 7, 2008 | 04:03 PM
andym's Avatar
andym
Old Mar 7, 2008 | 06:39 PM
fordmancounty
ok thank you well that answer's my next question. so i have another problem that i will have to try to figure out. my fuel pump's have no power to them when i turn on the key to start the truck. thank you again.
Old Mar 7, 2008 | 06:41 PM
andym's Avatar
andym
Check the fuel pump relay, the connector behind the dash switch, and the inertia switch. Those are the most common causes.
kbrenner536
Aug 30, 2011 01:07 PM
kjett
Offroad & 4x4
Feb 29, 2008 12:28 PM
Greywolf
Maryland Chapter
Jan 13, 2007 10:50 PM
79f-250custom
16
Feb 27, 2006 10:01 PM
mtgrzlyman
16
Nov 1, 2005 05:50 AM
